11-29-2019, 07:21 AM | #1 |
Pebble Pounder Join Date: Mar 2019 Location: Ecuador
| Mamba micro X beeping
Hello there, I installed a Mamba micro x with a 3700kv castle slate on my Axial Capra. After a few minutes of playing (mostly rock crawling) it makes 3 beeps (short, long, short) and it stops working. I’m sure it’s not the battery since I reconnect the system and it works again. Is it a temperature problem? Or a configuration thing? Really don’t wanna spend on a full size mamba X. Any suggestions? |
11-29-2019, 07:39 AM | #2 |
Rock Crawler Join Date: Jan 2019 Location: Calgary
| Re: Mamba micro X beeping
ESC is overheating
11-29-2019, 04:51 PM | #3 | |
Quarry Creeper Join Date: Feb 2008 Location: US
| Re: Mamba micro X beeping Quote:
11-30-2019, 10:47 AM | #4 | |
11-30-2019, 10:57 AM | #5 |
Did you try touching the esc to see if it's hot? Any time you try a new motor or setup, it's good practice to check the motor and esc Temps every few minutes so you don't burn them up. Sent from my SM-N950U using Tapatalk |
Mamba micro X beeping - Similar Threads | ||||
Castle Creations Micro Mamaba X problemI have the micro mamba x with a 4100kv motor, | Steelone232 | Electronics | 1 | 06-12-2018 08:56 PM |
