12-17-2019, 01:08 PM | #21 | |
| Re: Reefs servo junk!!!! Quote:
The gears are aluminum and cheap aluminum at that. He did another interview at proline by the fire last summer announcing the triple 9 servo. 999 oz at 7.4v and 1600 oz at 8.4v. Yeaaaaaaa | |
12-17-2019, 01:27 PM | #22 | |
Yeah sure is right. I wonder if his current servos even put out what they claim...doubtful. | |
12-17-2019, 01:49 PM | #23 |
Quarry Creeper Join Date: Nov 2015 Location: US
Ill stick to Hitec. Ive warrantied servos through both hitec and reefs and the process via hitec was smooth without issue. I had to have phone calls, upload videos and the whole process soured me on the reefs brand. I have a new 555 that is sitting on the bench if anyone wants to trade it for a similar spec hitec I did go with the futaba A700 on the Capra when I discovered the 7954 was discontinued. To be determined. Specs look great though |
12-17-2019, 02:26 PM | #24 |
Newbie Join Date: Oct 2017 Location: N.C
The owner of reefs did a podcast with bigsquid rc and it seemed like they knew more than him which is saying something. I'll stick with Savox or Xpert. Has anyone found if the Reefs is a clone of another servo (I.E JX) or if it is an original design?
12-17-2019, 02:46 PM | #25 | |
Newbie Join Date: Nov 2019 Location: Pocono Mountains
I have had the same promodeler for 4 years now, 4 recon G6's one 12hr fix enduro and lots of trail time. Yes I have replaced gear sets in it when it gets sloppy, but that is maintenance not a failure. But yes to what your said. I think the biggest issue with recommendations is most people don't put all that much time in, so they don't have real good observations, just an impression. I tell my friends/trailing buddies who I recommend promodelers to if they don't like it I'll buy it from them. No ones taking me up on it. | |
12-17-2019, 02:55 PM | #26 | |
https://m.alibaba.com/product/606018...specifications | |
12-17-2019, 03:26 PM | #27 |
| Re: Reefs servo junk!!!! |
12-17-2019, 03:58 PM | #28 |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
I only buy servos with steel gears either hitec or Savox. I've stripped titanium in the past, and aluminum is too soft. You buy quality, you cry once. You don't, you cry twice Sent from my LM-G710VM using Tapatalk |
12-17-2019, 04:16 PM | #29 |
Good catch white trash. I looked pretty hard to see if they were clones but could not find anything. Might have to buy one or two just to annoy the reef's fanboys. |
12-17-2019, 04:26 PM | #30 | ||
Quote: | ||
12-17-2019, 06:47 PM | #31 |
Quarry Creeper Join Date: Nov 2009 Location: Hickory,NC
Well this doesn't look good on Reefs part. I sent the email, pics and video of the servo and all the other info that they wanted for a possible warranty replacement. That was Sunday evening. 2 days and still no response. Last edited by cul8tr; 12-18-2019 at 04:08 AM. |
12-18-2019, 06:58 AM | #32 | |
Start your own servo business, call it Reep's RC, name the servos the 445 and 556, sell them for $20 less than Reef's servos, then wait for the adoration from FB morons to roll in. | |
12-18-2019, 07:13 AM | #33 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
| Re: Reefs servo junk!!!! Mechanical gears can definitely be a wear item in a servo that's used extensively. Breaking them is one thing, but wearing them out is another. If you use a servo enough to wear out steel gears, kudos to you!
12-18-2019, 07:44 AM | #34 | ||
In this case I was specifically talking about gears in a servo. Gears in a servo aren't spinning thousands of RPM's and if you wear them out over the course of many years I can see that. Wearing them out in 4 years seems like a short life. But some people use their rigs more than I do and also use them harder than I do. | ||
12-18-2019, 09:51 AM | #35 |
| Re: Reefs servo junk!!!! LOL. Interestingly reefs claim that they use a generic case with gears that they make separately. I'm 100% positive that is BS. Someone should get a k-power one to compare with a triple 4.
12-18-2019, 10:01 AM | #36 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
| Re: Reefs servo junk!!!! I'd grab that K-Power right now for this comparison but they haven't hit AliExpress yet and the seller on AliBaba has a 5pc min order - I'm not prepared to dump $300 into this right now but I'm tempted...
12-18-2019, 10:12 AM | #37 | |
But, I'll agree, that if he's replacing gears too often, it could point to something else being a problem, but knowing how well the Promodeler gear shafts are supported, I'd be surprised if that's the case. As for lubrication, I suppose that's on the user after the first set of gears. | |
12-18-2019, 06:45 PM | #38 |
Pebble Pounder Join Date: Jun 2018 Location: New Zealand
12-18-2019, 07:11 PM | #39 |
12-18-2019, 07:24 PM | #40 |
Reefs servo junk!!!! - Similar Threads | ||||
REEFs Rc Tripple4? | FTRC | Electronics | 9 | 11-22-2020 04:20 PM |
Is my servo junk or am I an idiot? | pretzalballot | Electronics | 4 | 04-08-2017 02:08 PM |
Hi-tec mini 225 servo junk? | 73bronco | Axial AX-10 Scorpion | 9 | 09-20-2010 11:15 AM |
