Thread: Holmes Revolver V2 choppy slow speed
Old 02-14-2020, 08:23 AM   #1
ECT
Default Holmes Revolver V2 choppy slow speed
Hi all, I’m running a Mamba Max Pro and revolver v2 normal size 1800kv in my Element kit with an 18t pinion. The startup is a little jumpy and low speed control is jumpy. Feels like a light switch with the motor either providing power or not right off idle. I’ve purchased a 14t to try and slow things down and I’ve adjusted the throttle curve in castle link to try to smooth things out.
I really like the novelty of the motor, is there anything else I can do to make it crawl and cruise at sloooow speeds smoother? Perhaps step over to a sidewinder 4?
Thanks!!
ECT is offline   Reply With Quote
Old 02-14-2020, 09:05 AM   #2
Default Re: Holmes Revolver V2 choppy slow speed
18t pinion is very high for a crawler. i try to stick between 10t to 15t
Sent from my SM-G965U using Tapatalk
midwest_rippa is offline   Reply With Quote
Old 02-14-2020, 10:37 AM   #3
CODYBOY's Avatar
Although your answer may be right in this case, to say "18t pinion is very high for a crawler" is incorrect. There are so many variables for correct gearing out there depending on what brand you are running. Just saying your statement is to generic and may mislead someone else new to the hobby.
Ernie
CODYBOY is offline   Reply With Quote
Old 02-14-2020, 10:42 AM   #4
Moderator
JatoTheRipper's Avatar
My Revolver was the same way. I never could get it to go smoothly nor could I eliminate the cogging so I sold it. I believe mine was a v1 though. All of the other Holmes motors have been excellent for me.
Old 02-14-2020, 10:59 AM   #5
You’re issue is the MMP. JRH has told us to use the MMX or SW4.
The MMP is the base for Holmes BLE, and sadly is past it’s prime.
I still run my MMP and BLE with PullerPro’s and a long flat curve. No chatter, cogging just smooth creep unless I need to spin the tires.
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 02-14-2020, 11:56 AM   #6
ECT
Thanks all, I will try out the SW4.
Old 02-14-2020, 02:13 PM   #7
I initially tried my revolver with a mmp and it was as you describe. I switched to the sw4 and its smooth as butter. Totally an esc issue.
frdtrkguy is offline   Reply With Quote
Old 02-14-2020, 03:54 PM   #8
ECT
Awesome! Looking forward to using this cool motor.
Old 02-14-2020, 04:06 PM   #9
The Element runs a 48P spur and pinion. An 18T pinion and 78T spur is equivalent to a 13T pinion with a 56T spur gear.
GA Dawg is offline   Reply With Quote
Old 02-14-2020, 04:09 PM   #10
thanks for this info. i dont have an element so i didnt know that. i shouldve read the original post more closely before commenting but i just wanted to try to help in any way i could as i dont have a revolver. it looks as though the MMP is the problem now though thanks to other comments.
Holmes Revolver V2 choppy slow speed - Similar Threads
Holmes Revolver 1800kv Bugs Crawler Electronics 18 01-25-2019 11:09 AM
Holmes Revolver S 540 Dezertdirt Electronics 8 01-19-2014 08:06 PM
Holmes Revolver Help Needed yeahright Electronics 1 06-28-2010 01:34 AM
