05-15-2020, 08:06 AM | #1 |
Newbie Join Date: May 2020 Location: SANTA CRUZ
| Charging Amperage
What amperage should I be charging my LiPO's at? Default on my charger is 2.0 amps. Charger is a UP240 AC Plus.
05-15-2020, 08:22 AM | #2 | |
Newbie Join Date: Feb 2020 Location: Hilton Head
| Re: Charging Amperage Quote:
Example: A 3500mah battery should be charged near 3 amps, a 5000MAH battery near 5 amps. | |
05-15-2020, 09:01 AM | #3 |
Newbie Join Date: Mar 2020 Location: Ballston Spa
I come from a 1/10 scale racing perspective. I charge all my 2s lipos at 15amps, and have been doing this on packs for well over a year and they have held up very well. For me the most important thing to do with lipos is not to over discharge them, and always leave them on storage charge when not using them. |
05-15-2020, 09:35 AM | #4 |
RCC Addict Join Date: Jun 2016 Location: Germany
Depends on your Lipo, to be save and to pamper the lipo 1C charge is the best. But some lipo also allow higher charge rates, mostly high quality high C rate lipos used for race drones. I have some 3s 1300mAh 65C which i can laod with up to 10C. |
05-15-2020, 11:03 AM | #5 | |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
What in the blazes charger are you using that'll push 15Amps!? | |
05-15-2020, 11:11 AM | #6 | |
Most (all?) batts are rated for a minimum of 1C, many are rated for 2C but not many are higher taht that. Even on batts that are rated higher, increasing the charge rate reduces pack life. LiPo chemistry can only sustain so much force in electron transfer that pushing them too hard has a definitevly negative impact. It's already been dfeined but I'll go over it for you again: C=charge (or discharge) rating. 1C= 1x capacity So if the pack is 2200mAh the capacity is 2.200Ah So for that pack, the 1C charge rate would 2.2Amps x 1 = 2.2Amps A 2C charge rate would be 4.4Amps. Discharge rate follows the same formula but the C rating numbers are typically 25+ 2200mAh 40C pack: 2.2Amps x 40 = 88Amps sustained discharge *EDIT 1C is always the best charge rate to maximize battery life. Higher rates can be safe based on manufacturers recommendations but also reduce the longevity of the pack. I use up to 2C commonly but never higher. Last edited by QuesoDelDiablo; 05-15-2020 at 11:13 AM. | |
05-15-2020, 11:21 AM | #7 |
| Re: Charging Amperage |
05-15-2020, 12:22 PM | #8 |
Thank you all for the advice. It is much appreciated. New to the LiPO scene, came from old school 1:10 buggies.
05-15-2020, 12:27 PM | #9 |
Charging Amperage - Similar Threads | ||||
ESC Reverse Amperage | JKMotorsports | Electronics | 2 | 01-01-2012 01:42 PM |
Usable amperage...... | Pappy | Electronics | 29 | 06-09-2010 11:30 PM |
BEC amperage | RacerScott | Newbie General | 3 | 02-24-2010 10:47 PM |
Motor amperage | tedmales | Electronics | 0 | 09-21-2008 12:14 PM |
What Amperage to Charge Your Battery at? | Shaun | Electronics | 8 | 08-19-2008 09:22 PM |
