06-25-2020, 10:55 PM | #1 |
Quarry Creeper Join Date: Nov 2018 Location: Oakley
| What size battery connector?
I just put XT60’s on my TRX4 but wondering if they would work on my Rock Rey. My Rock Rey is powered by a Mamba Monster X with an HH Puller Pro 540 2700 kV. Is an XT60 enough for this setup or should I step up to XT90’s?
06-25-2020, 10:57 PM | #2 |
RCC Addict Join Date: Jun 2017 Location: Canada
| Re: What size battery connector?
XT60 is fine unless it's a high power 1/8 bashing truck Sent from my Pixel 2 XL using Tapatalk |
06-26-2020, 09:14 AM | #3 | |
| Re: What size battery connector? Quote:
My only worry is the 3S pack I typically use in my Rey is 10 gauge wires. Im not sure I can fit those in the XT60 bullets. At least not with my soldering skills. I feel like the 12 ga wires on my TRX4 battery were a little snug even. Is the XT90 a larger bullet. | |
06-26-2020, 09:23 AM | #4 |
Yeah the XT90 is larger and is rated for 90 amps while the 60's are rated for 60 amps. Bigger wires are easier to solder to a XT90 as the bullets are larger. I like to use the XT90 on my bashers and especially on higher voltage setups. |
06-26-2020, 12:37 PM | #5 |
Quarry Creeper Join Date: Jan 2017 Location: Olathe
Voltage isn't an issue for the XT60's. I would recommend the XT90's for 6s and over just because the XT90 is offered with an anti-spark edition, but the XT60 has no issues running at higher voltages. Amperage heats up connectors, voltage does not.
What size battery connector? - Similar Threads | ||||
TRX4 Stock Titan Motor Connector size? | Jackson233 | Traxxas TRX-4 | 14 | 11-17-2019 06:58 PM |
what's the name of this connector? | muddeprived | Electronics | 16 | 06-04-2009 12:15 PM |
what connector and wire size for custom batt? | dave m | Losi Mini-Rock Crawler | 4 | 02-12-2009 05:50 PM |
how do i know what size deans connector | ykcor | Newbie General | 2 | 04-17-2008 11:43 AM |
