Thread: Axial Capra with HW 1080 and Reef's 555
Old 07-19-2020, 11:45 AM   #1
Default Axial Capra with HW 1080 and Reef's 555
Has anyone setup the Capra with the following? Do you think I will need a BEC? If yes, which one do you recommend with how many Amp rating (10 or more)?
- Axial Capra Kit
- HW 1080 ESC
- Reef's 555 Servo
- Flysky GT5 Radio Receiver
- SX107 Dig Servo
- Tattu 3s LiPo Battery 75C (11.1V)
inomad is offline   Reply With Quote
Old 07-19-2020, 12:02 PM   #2
Default Re: Axial Capra with HW 1080 and Reef's 555
I suggest using a 10A BEC in everything.
House is offline   Reply With Quote
Old 07-19-2020, 12:10 PM   #3
You'll likely want a BEC as that servo pulls over 4.3 amps at 6 volts per RC Review's tests (more at 7.4 volts obviously).
The 1080 bec is only rated to 3 amps.
The Castle 2.0 BEC is PLENTY to handle this servo, but I can't recommend it because I don't own, and have never used one.
IronOKie is offline   Reply With Quote
Old 07-21-2020, 01:43 PM   #4
I agree you'll definitely want to use a BEC with that servo.
I use the Castle 2.0 waterproof BEC in almost all of my rigs. It's expensive, but it's worth the price IMHO.
https://www.amainhobbies.com/castle-...153-00/p575484
NeoPyro is offline   Reply With Quote
Old 07-21-2020, 02:11 PM   #5
Moderator
JatoTheRipper's Avatar
Welcome to the site. I'd recommend a better servo, but yes you should use a BEC with a power hog servo.
You could get a Holmes SHV500v3 and have a better servo and you can power it direct so you don't need to be bothered with a BEC.
Old 07-25-2020, 09:42 PM   #6
Thanks everyone. Ended up with a Castle 2.0 Waterproof BEC and Holmes splitter.
Tags
555, capra, hw1080, reefs555
Axial Capra with HW 1080 and Reef's 555 - Similar Threads
Axial Capra JatoTheRipper Axial Capra 284 06-03-2021 07:47 AM
hobbywing 1080 esc ruining axial/tactic recievers ?!? andymac0035 Electronics 7 02-13-2020 09:06 PM
I need help with a 555 timer ON THE FARM Chit Chat 3 02-27-2008 10:34 PM
