Thread: Hyperion Duo 2 charge LIHV?
Old 07-27-2020, 08:10 AM   #1
Default Hyperion Duo 2 charge LIHV?
I've had a Hyperion Duo 2 Eos0610i charger for quite a while and I ordered a Protek lihv battery for my Capra. Will this charger charge that battery to capacity?
josh9mile is offline   Reply With Quote
Old 07-27-2020, 08:41 AM   #2
Default Re: Hyperion Duo 2 charge LIHV?
That info should be covered in the user's manual. If you don't have your manual you can do a quick search for it online.
Inspector86 is offline   Reply With Quote
Old 07-27-2020, 08:47 AM   #3
In absence of a dedicated lihv mode, check in your settings menu to see if there is an option to increase the charge ending voltage from 4.2V/cell. The Hyperion is an older charger so it may not have that adjustment available.
Just remember to set it back to the original setting before charging any normal lipos.
svt923 is offline   Reply With Quote
Old 07-30-2020, 09:40 PM   #4
Finally got around to putting that on the charger. Can only go up to 4.28v per cell though. Kind if a drag. But it will still be fine since I dont feel like buying a new charger quite yet.
Old 07-31-2020, 05:40 AM   #5
That would be fine until you get a charger that can charge LiHV. LiHV is 4.35V/cell when the charging stops. Your max of 4.28V is fine. You just aren't taken full advantage of the LiHV pack. No harm, no foul.
Kingmeow is offline   Reply With Quote
