10-11-2020, 12:23 PM | #1 |
Newbie Join Date: Oct 2019 Location: Texas
| Soldering brushed motor's commutator?
I'm thinking of getting a couple of the Tamiya 23T Super Stock motors for a Clod Buster build in the future. They look like very good quality motors for the price. Should provide much better performance compared to the typical silver can kit motors included in Tamiya kits. 26,500 - 27,500 RPM and 500 g-cm torque. I know that high performance hand wound motors typically have the winding soldered directly to the commutator's tabs for better performance. Most machine wound armatures don't have this. I think they're crimped on instead. So I thought about a little tinkering and try soldering the comm's tabs. I don't know if high temp soldering can have a bad effect on the comm ... like warping the comm's segments due to the high temperature ... High Pb content (high temp) solder melts at 560+ °F so I would have to crank my soldering station to near max setting if I do try this. Has anyone tried this before with success? Or is it too risky and I should leave the motor alone the way it is ? |
10-11-2020, 12:54 PM | #2 |
| Re: Soldering brushed motor's commutator?
I suspect you would just open a can of worms for not much benefit. Maybe JRH will chime in but personally I would not attempt it too much potential down side.
10-11-2020, 07:29 PM | #3 |
Quarry Creeper Join Date: Dec 2013 Location: The Garden State, North of I-80
I agree with the can of worms. Windings are done with magnet wire which has a clear thin layer of polyurethane (or similar) coating. With machine winding, the crimp pierces the insulation to make the contact with the wire. If you want to add solder, you'll have a tough time to clear out the thin coating around the crimp area so solder can adhere to the magnet wire. And if you are not careful, you can disturb the insulation on the adjacent wires and and cause shorts. |
10-12-2020, 03:00 PM | #4 |
This is not why hand wound motors are better. don't bother soldering that for no reason. Some hand wound motors are better then machine wound because they manage to fit more copper winding in the motor. I say some, because I doubt I could wrap an arm any better then the machine can, but Holmes does, that's why they are better, More copper. Secret exposed... goto.play(Unsolved-Mysteries.mp3)
10-14-2020, 09:26 AM | #5 |
Appreciate all the feedbacks guys. I'll leave these budget motors alone if I end up getting them, maybe just swap the bushings out for bearings. And leave it to the pros who can build high spec hand wound motors if I want the best performance.
Soldering brushed motor's commutator? - Similar Threads | ||||
Commutator Cleaner | MAGNUMB | Electronics | 11 | 07-30-2020 09:34 AM |
Tamiya 53486 Commutator Cleaning Brush? | fyrstormer | Electronics | 6 | 09-24-2017 04:32 PM |
Burning through soldering tips? And other soldering questions | losikid | Electronics | 14 | 12-16-2010 10:04 AM |
