Thread: dynamite tazer 15t help
Old 02-27-2007, 10:02 AM   #1
Default dynamite tazer 15t help
i have all my elertronics hooked up and nothing works please help
crawler02 is offline   Reply With Quote
Old 02-27-2007, 10:08 AM   #2
i told you...see
one of your posts got deleted
again send pics to see what you are doing maybe its the battery taht isn;t charged or a bad esc or a bad rx
chivas72 is offline   Reply With Quote
Old 02-27-2007, 10:11 AM   #3
I had one on my tlt and it didn't have enough power to run everything
whalebone is offline   Reply With Quote
Old 02-27-2007, 10:27 AM   #4
i runn a 19t on one and it works fine with a 55t , 6cell 3300, and two servos
Old 02-27-2007, 06:26 PM   #5
Ok, the problem is when i'm trying to program it. The directions are to push the button on the esc and the light turns red, give it full throttle. Push the button again and it will turn green, give it full reverse. Then push the esc again, it will turn red again and have the throttle at neutral position. Then the lights will go out on the esc and programing is done. But i can only get the full throttle and full reverse. When im at the stage after i push the button once it is green, the lights go out and nothing happens. I need a lot of help.
