03-02-2007, 08:36 AM | #1 |
Newbie Join Date: Mar 2007 Location: Woodbury
| Steering not working properly??????
ok guys got a question! and from what i read u guys can answer anything! so here goes! i got a TLT based rig with front and rear steer ( hitec 645's) i have the TQ3 radio with rear steer hooked up, i have a older rooster one touch setup esc, 65t lathe motor, r2 tranny, 10t pinion, and my battery i run is a brand new 3000 mah! now for my problem! one second it steers fine both front and rear steer! then the next second it wont turn @ all i have charged the battery and it still does it right away! do you think this is cause my old esc iam running? or do u think i need to run an rx pack? any help would be great guys! thanks CJ |
03-02-2007, 08:49 AM | #2 |
I wanna be Dave Join Date: Sep 2005 Location: R.I.P. Chip
Try running only one steering servo and see what happens. The BEC should be able to handle two 645's but you never know.
03-02-2007, 08:52 AM | #3 |
ok let me try that first! ill be back!
03-02-2007, 09:08 AM | #4 |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
You will need to use a reciever pack or a voltage regulator. The original roosters BEC only supplys 0.5amps, which is not enough for 2 645mg's.
03-02-2007, 09:15 AM | #5 |
ok well it works fine now with the rear steer unhooked! so what if i step up to a tekin rebel 2? instead of running a battery pack or regulator! i thank you guys very much!
03-02-2007, 09:26 AM | #6 |
I would not waste your money on the TRII, I would spend a little more and get a Mamba max.JMO |
03-02-2007, 09:31 AM | #7 |
ok thanks guys |
