01-10-2023, 06:38 PM | #41 | |
Rock Crawler Join Date: Jan 2022 Location: st louis
| Re: NEW Hobbywing Fusion SE Quote:
Sent from my SM-S906U using Tapatalk | |
05-31-2023, 05:01 PM | #42 |
Rock Crawler Join Date: Dec 2013 Location: Tuxedo NY
I’m not sure the super low startup is quite as smooth as the pro, like the initial step is a bit jerky at weird angles. Has anyone else noticed this? |
05-31-2023, 06:06 PM | #43 |
Rock Crawler Join Date: Nov 2019 Location: Erie
| Re: NEW Hobbywing Fusion SE The startup on the SE (I do own 1) is absolutely NOT as slow or smooth as either the original 1800 (I have 3) or 2300 Pro (I have 1). It’s certainly a good performer and an amazing bargain, but yes, I definitely took notice of the difference.
06-01-2023, 09:35 AM | #44 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
I am putting a pro in my current build, pretty stoked to try it out. I love a brushless setup but find the squeal of the Mamba a bit much when I am crawling a nice serene spot in the woods. This one should be whisper quiet. Hope this one is as quiet as I am expecting
06-01-2023, 12:15 PM | #45 | |
Rock Stacker Join Date: Mar 2023 Location: Orange County
06-01-2023, 01:02 PM | #46 | ||
Quarry Creeper Join Date: May 2023 Location: Hungary
I will buy Both the 2300pro and 1800se. Try them both before buy one more of these to the third later. I believe the 1800se is exelent in 2speed crawlers. And in 1 speed you maybe need that 2300 pro? Also what if i like to use 2.2 big heavy wheels. 3s. Maybe the Pro is safer then? Or is the SE strong too? Have you try weight pulling at asphalt anything? This is exelent way to find out if combos are strong, after pulling weight for 30seconds you can feel if there is any heat or not. This tells alot how strong they are. Check this video out please, i saw it yesterday https://youtu.be/cWSdUgmOT4I?t=83 he did try overheat this PRO combo Quote:
I have watch some videos now about this pro. Many professional Crawlers LOVE this | ||
06-01-2023, 07:25 PM | #47 | |
06-01-2023, 08:54 PM | #48 |
| Re: NEW Hobbywing Fusion SE |
06-04-2023, 09:47 PM | #49 |
| Re: NEW Hobbywing Fusion SE I got a free gift card from a rewards program so I picked up another HWPro. It finally retired my HH w/ 1080 maybe for good. Or at least until the next rig shows up The 1080 has been relegated to temporary duties in the past on the 2 TRX's and 1 Vanquish.
NEW Hobbywing Fusion SE - Similar Threads | ||||
TRX4 Hobbywing Fusion lighting | 09graham.wj | Electronics | 4 | 10-30-2021 04:36 PM |
Hobbywing Fusion in 1.9 Wraith | fquails | Axial Wraith | 1 | 08-05-2021 06:31 PM |
Hobbywing Fusion | deephis46 | Electronics | 2 | 02-06-2021 06:49 PM |
HOBBYWING Fusion 1800KV | Rcing4life | Scale Videos! | 0 | 01-19-2021 12:14 PM |
