03-05-2007, 04:05 PM | #1 |
Quarry Creeper Join Date: Jun 2005 Location: quarryville
| hitech servo not working ?
i jsut got a new hitec high torque servo (hs-635hb) and the dang thing dont work ?? my old servo works fine on the truck but this one doesnt do anything at all ?? is there anything i dont know orrr is it just a dud ? |
03-05-2007, 08:53 PM | #2 |
Pebble Pounder Join Date: Aug 2006 Location: Mobile AL
Hitec has a universal connector that you can plug in backwards to Futaba/Traxxas and Hitec... check to make sure its plugged in the right way... Later, Jake |
03-05-2007, 09:24 PM | #3 |
plugged it in both ways even cut the plug off and direct connected bare wire in where it pluggs in still nothing
03-06-2007, 12:04 AM | #4 | |
Did you actually "cut" the wires? If you did, why? Just tweak the plastic tabs that retain the connectors in the plug, takes 2 seconds to remove. | |
03-06-2007, 05:44 AM | #5 |
Pebble Pounder Join Date: Oct 2006 Location: raleigh, nc
you may have to rearrange the order of the wires... all the plugs that go into the Rx should be in the same color order... I had the same issue with a new ESC and I had to change the order of the wires, after that it worked perfectly. |
03-07-2007, 11:07 AM | #6 |
im gonna swtitch them now just waiting for my battery to charge.. (hapen to know the order lol ) ?
03-07-2007, 11:44 AM | #7 |
Rock Stacker Join Date: Feb 2007 Location: bristol
i thought all the servos were suppesed to be universal know just may hev to use the servo reverse switch
03-07-2007, 11:48 AM | #8 |
i just got it working.. i think they might jsut get the wire confiuration messed up when they put the end cazps on.. ?
