03-06-2007, 04:40 PM | #1 |
Pebble Pounder Join Date: Feb 2006 Location: FRANCE
| 2 amps?
Do you think this esc would handle my two 65t motors and dual steering?? 130085623119 Found this on Ebay ... I wonder the BEC amps an E-savage esc would deliver... |
03-06-2007, 08:48 PM | #2 | |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
03-07-2007, 08:54 AM | #3 |
Rock Crawler Join Date: May 2006 Location: Surrey, BC, Canada
It'd handle the 65's no probz, but they don't list the actual BEC voltage... Just the amperage... 2A isn't enuff, no... You'll need an RX pack... But for the cost, you could get an old EVX and mod it for single pack for a LOT less than that ESC and be in the same boat, per se, as you want to be... Altho', if you wanted to run some hot motors, this/d be a good ESC for that... Not sure what the EVX's motor to cell limit is... |
03-07-2007, 09:12 AM | #4 |
RCC Addict Join Date: May 2006 Location: USA
get a tekin rebel 2 they are proven in the rock crawling scene, can easily handle 2 65 motors, and easily handle 2 servos with ease, they have 5 amps at the bec. http://www.thecrawlerstore.com/electronics.html |
03-07-2007, 02:08 PM | #5 |
How many cells can the TR2 handle?? |
03-07-2007, 05:06 PM | #6 |
FEATURES: Works with all motors down to 10 turns Fully proportional Forward, Brake, and Reverse QuickTune one button setup Adjustable Reverse delay from 0-4 seconds plus Reverse disable High frequency regenerating operation extends runtime and increases motor life Factory installed motor and battery terminals High efficiency heatsink for cool operation Thermal sensor for optimum performance INCLUDES: (1) Tekin Rebel 2 ESC (3) Zip Ties (3) Squares of double sided tape (3) 0.1 uF Motor Capacitors (3) Receiver Connectors, KO, JR (FUT is installed) REQUIRES: Installation SPECS: Controls: Forward/Brake/Reverse Input Voltage: 4-10 Cells (Stock Motor) 4-8 Cells (Mod Motor) On resistance: 0.0038 Frequency: 2000Hz Power Wires: (4) 15 Gauge Silicone Plugs: Tamiya/Bullet BEC: 6.0V / 5.0A Weight (with wires): 2.4oz (68g) Size: 1.8" x 1.4" x 1.0" (46mm x 35mm x 25mm) Motor Limit: 10 Turn (6 cells) |
