03-14-2007, 07:48 PM | #1 |
Newbie Join Date: Mar 2007 Location: Woodbury
| ESC smoking! hahaha ok so its smoking! i have no reverse anymore either! did i blow it? its an older novak rooster reversible! c-yas CJ
03-14-2007, 08:12 PM | #2 |
Rock Crawler Join Date: May 2006 Location: Surrey, BC, Canada
Once ya let it out, it's impossible to put it back in... Chances are it's cooked, yea...
03-14-2007, 08:26 PM | #3 |
yeah i figured! it was so hot i couldnt touch it hahahah |
03-14-2007, 08:29 PM | #4 |
What ESC and motor was that combo? That's a tad on the too warm side f ya can't touch it.. hehe
03-14-2007, 08:47 PM | #5 |
is a older novak rooster reversible, 55t lathe motor, 15t pinion, r2, tq3, hi-tech 645, 3000mah battery. this i the first problem i had with it. it has run fine up till today it was running fine the i had no forward! then it was fine and then it had no reverse and stayed that way! the green light on it was going crazy in reverse! like i said it is an old esc
03-14-2007, 09:52 PM | #6 |
That's one for the "Wall of Wonder" it sounds like... It shouldn't have smoked with that gear... >shrug< Maybe it was made on a Monday or Friday...
03-14-2007, 10:48 PM | #7 |
Newbie Join Date: Jun 2006 Location: Charlotte
sounds like it got to hot and the heat destroyed something inside such as a tranistor or one of its counterparts
03-15-2007, 06:31 AM | #8 |
everything is brand new but the ESC so ill just buy a new one and see what happens plus then ill be able to run my rear steer again ! thanxs guys!
03-15-2007, 08:28 AM | #9 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
Either due to long-term heat/cool cycles, or like DVO says - you got one that was finished up at 4:55 pm on a Friday...
03-15-2007, 09:29 AM | #10 | |
03-15-2007, 11:46 AM | #11 |
Winner of the '07 RCC dumbass award! Join Date: Nov 2006 Location: Up on a Mountain, out in the Woods
Are you sure your motor was not shorting? That ammount of heat sounds impossable with that setup... |
