03-15-2007, 12:24 PM | #1 |
RCC Addict Join Date: Dec 2006 Location: Flatwoods
| Waterproofing the switch?
Hello, I searched but could not find an answer. I am building a scale trail rig and I am water proofing everything on it. The electronics will be in a water tight box on the chassis and that will be covered by a hard body. I want to be able to turn the truck on and off by mounting the switch to the frame. How does one water proof the switch on the ESC? Just cover the back of it with liquid electrical tape and try to get as much dielectric grease in it as possiable? Or is there a better way? Or does it even matter? I have a small water proof toggle switch, could a person use that or would the resistance be to high? Thank you for the help. |
03-15-2007, 12:41 PM | #2 |
It really doesnt matter, but your toggle switch would work. I just hack all my plugs off and use the battery plug to turn it on and off.
03-15-2007, 02:11 PM | #3 |
Rock Crawler Join Date: May 2006 Location: Surrey, BC, Canada
03-16-2007, 12:08 PM | #4 | |
03-16-2007, 12:40 PM | #5 |
Seems to work good so far... I juse used the tops off some of the big roundy like balloons on the switch and zapstrapped it wih a tiny one to keep it from mvoing... Then I stuffed it thru the hole I cut for it and lined it with high heat silicine (all I had at the time) and so far hasn't let a drop of water in yet... I haven't had it in any kind of submerging situation but it does keep the wet outta my electronics nively...
03-16-2007, 01:17 PM | #6 |
Winner of the '07 RCC dumbass award! Join Date: Nov 2006 Location: Up on a Mountain, out in the Woods
Lookinto RC boating if you wanna keep a switch and want it waterproof. I got one years back and it was nice! Can't remember where I got it though, sorry. |
03-16-2007, 05:28 PM | #7 | |
Quarry Creeper Join Date: Jan 2007 Location: wilkes-barre
03-18-2007, 03:09 AM | #8 |
Newbie Join Date: Feb 2007 Location: Tucson
put the switch in a balloon and seal up the hole kind of like what daviolentone did except no tupperware , should work well ,especially if you use a really small balloon
