03-17-2007, 09:20 AM | #1 |
I wanna be Dave Join Date: Nov 2006 Location: spring hill TN
| reciver pack
Is it safe to run a five cell reciver pack with no voltage regulator eventhough the pack peaks at a higher voltage than the 6 volt that my servos are rated for.I am using hitec 805 servos,and a 5 cell 3200MAH reciver pack.
03-17-2007, 10:43 AM | #2 |
Rock Crawler Join Date: May 2006 Location: Surrey, BC, Canada
Don't see why not... I use 5 cell 2/3A hump packs and 5th scales use the subC cells for RX packs... With a pack that size tho', you might want to monitor the servo's and such... That's a lot of amperage going into some little wires... The only issue that MIGHT arise would be that... Too much amperage and the wires fry out... |
