03-17-2007, 07:14 PM | #1 |
Rock Crawler Join Date: May 2006 Location: United Kingdom,Scarborough
| Motor Getting hot.
HI i have just got a old buggy going and i think it has the 27t tamiya motor. It has not been run in years the motor. The motor is running with a 17t pinion. COUld it just be that the motor is getting hot and that once it gets working again will it cool down abit? I have checked and nothing is binding Thanks james |
03-17-2007, 08:48 PM | #2 |
Rock Crawler Join Date: May 2006 Location: Surrey, BC, Canada
Hmmm... Mebbe give it a spray with some motor spray then give it a quick dunk in water with 4 cells on it for a few seconds... Then give it really good dousing with the motor spray again... Oil the bushings and try it again... If it hasn't been run for a few years, it may need some care to get it back into shape... Give the above a try and see if that helps.. If not, then it may have just sat too long... The stock Mabuchi motors aren't that expensive anyways... They cost less than a can of motor spray, actually... |
03-17-2007, 08:51 PM | #3 |
O.k thanks Could i run it at 7.2v when in the water? Last edited by Moondust1950; 03-17-2007 at 09:02 PM. |
