04-18-2007, 07:58 AM | #1 |
Rock Crawler Join Date: Mar 2004 Location: Where it's wet
| Nomadio React Q
Can I set up a switch or button to reverse the throw on the rear steer servo when I touch it? This would be with mixed channels, all 4 tires ran from the wheel. For example if I wanted to switch from 4ws to crab while running. I dont care for indi rear steer with a separate switch. |
04-18-2007, 08:23 AM | #2 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
you can with the sensor. the latest software enables you to program the keys on the keypad for such functions. sorry, i know this dosnt help you any but i was happy with it. also nomadio has a forum for talk/tech help with nomadio products.
04-18-2007, 10:46 AM | #3 | |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
From PM: Quote:
No, you can't run in model select mode with the Nomadio. Here's why: When you bind the Nomadio transceiver with the TX unit it will recognize that transceiver with that specific model memory. For example, if I configure my FJ40 with a transceiver, then configure my 2.2 comp rig, I can't inadvertently power up the 2.2 rig if I have the FJ40 selected on the radio. I just looked at the React's desktop software, specifically into the SoftKeys functions... You can program a pushbutton to reverse any channel. ;) Last edited by JasonInAugusta; 04-18-2007 at 10:52 AM. | |
04-18-2007, 10:55 AM | #4 |
05-12-2007, 09:28 PM | #5 |
I picked up a React and im really happy with it so far. Seems to work great Just need to tweak ch4 a bit still. I need to find out if I can run a transceiver batt pack on a Y harness with the ch4 servo... Thanks again JIA and jason for your help |
