03-13-2005, 08:44 AM | #1 |
Rock Stacker Join Date: Feb 2005 Location: Rachel Rays Bed
| dual motor question
wired up my super rooster with twin motors last night was wandering should both motors start turning at the same time if so why would one start before the other . i tried it with stock type motoers and some green machine twos both did the same thing i have them wired yellow to pos then neg to pos then the blue wire to the other motors neg .. |
03-13-2005, 08:51 AM | #2 |
RCC Addict Join Date: Mar 2005 Location: DODGING ROCK CHUCKERS
Welcome to axle stall, you should find all those answers in the clod tread |
03-13-2005, 09:00 AM | #3 | |
03-13-2005, 09:13 AM | #4 |
Sorry for the misunderstanding Dual motors normally means a clod but try just pitailing them to the esc |
03-13-2005, 09:46 AM | #5 | |
03-13-2005, 09:56 AM | #6 |
Ya to bad theres not spell check on the site, a lot of us could use It I ment pigtailing!! But I came off the 2 motors with 4 pigtails and directly attatched them to the leads from the esc Instead going from motor to motor. In your case, since your not using both motors and dont need to wire the rear in reverse, just go 2 + pigtails to yellow and 2 - pigtails to blue. hope that made sence |
03-13-2005, 10:52 AM | #7 |
yea i was just wandering why one motor would turn before the other , i had a clod once but it had the mechanical sc and i never ran it enough to notice the stall everyone talks about , my truck will be a shafty with one motor just was trying the two motors to see how it worked
03-13-2005, 03:33 PM | #8 |
Quarry Creeper Join Date: Nov 2004 Location: MANVILLE
IT could be the 2 motors are worn differently or you wired the 2 motors in series and that will be the cause
03-13-2005, 05:43 PM | #9 | |
03-13-2005, 08:18 PM | #10 |
Pebble Pounder Join Date: Jan 2005 Location: Kln, HKG
Novak site has good info about wiring dual motors. http://www.teamnovak.com/How_to/Dual.../dual_mot.html http://www.teamnovak.com/How_to/use_...tors/index.htm . |
