04-30-2007, 01:04 PM | #1 |
Pebble Pounder Join Date: Aug 2004 Location: Vienna
| Tekin died...ready for replacement.
Tekin Rebel 2 lost forward movement yesterday. Called Tekin and they said a transistor or two probably fried. No warranty, I've had the Rebel for almost two years and I do not want to spend $25-40 on the repair. It looks like the Mamba Max will be my replacement and eventually a Hyperion, but will the Max and Hyperion run well with 2/3A 1500 mah batteries? How about run times? (2.2 TLT, 7 cell Epic 1500 mah 2/3A batts, with Hitec 645 servo). I do not want to run sub C's and do not want the LiPo investment right now. A few weeks ago I was looking into the Mamba 25 and Revolver 2 and then a buddy mentioned the Qwark and Revolver 2 combo; would these prove to be a decent alternatives to the Max and Hyperion and which speedo do you prefer: Mamba 25 or Qwark? Is the difference between the Mamba and Qwark worth the extra cash for the Max? |
04-30-2007, 01:09 PM | #2 |
Quarry Creeper Join Date: Jan 2006 Location: colchester
go through holmes hobbies.jrh has the mamba max on sale right now
04-30-2007, 05:03 PM | #3 |
Newbie Join Date: Apr 2007 Location: Woodbridge
I think that the Max is worth the cash because it can be programmed by PC which, I think, would give you an advantage when crawling due to the added adjustability the PC allows.
04-30-2007, 05:49 PM | #4 |
I wanna be Dave Join Date: Dec 2006 Location: In Cali.
You looking at $120.00 for the Mamba max with programming features with the 25.00 link. It can run brushed mode until you can get the funds up to get a brushless motor. The Quark is 80.00 and it has no computer programming. Revolver will cost you another 40.00. John has a new motor coming to replace the Hyperion that should be better and a little less expensive. My money would be on the Mamba max. I have the link and a laptop and we can program it at the GTG. You can wait and save your money for the new motor John is coming up with. Tom |
04-30-2007, 06:15 PM | #5 |
Thanks Tom. Wonderful day of crawling yesterday huh? It seems as if I read somewhere that it is best to use sub C's or LiPo with a Max and Hyperion or equivalent. Any comments about using 2/3 A batts with Max and Hyperion or new model?
04-30-2007, 06:53 PM | #6 |
2/3a cells work just dandy. Your runtime will vary, but 15 minutes or longer are normal. I get 30 -45 minutes to a pack when driving slow and easy, less time when I punch the throttle a lot.
04-30-2007, 06:58 PM | #7 |
Once you use the Max, you'll wonder why you waited so long to switch! |
04-30-2007, 07:17 PM | #8 |
Thanks to all. John, which motor is going to be the Hyperion replacement or equivalent; is it the Crawlmaster 3014?
04-30-2007, 08:59 PM | #9 |
Yes, that will be the comparable. 1mm longer stator.
04-30-2007, 09:26 PM | #10 |
Rock Stacker Join Date: Jan 2004 Location: Morgantown
Ive been looking at the Mamba Max and I cant see anywhere were it says it will run a brushed motor Also if it does run a brushed motor can I wire it up to my two 55 turn lathes? Or will I have to buy two of their motors?
04-30-2007, 10:19 PM | #11 |
It will run two brushed motors just fine. You should wire your lathe motors in parallel.
05-05-2007, 06:09 PM | #12 |
I noticed that the motor leads on the Max has female connectors for a brushless motor using a male barrel connector. While running a brushed motor, should I just remove the entire lead from the speedo and save for a Crawlmaster BL? Should I solder in a new pos and neg of the same length as the stock wires for a brushed lathe?
05-05-2007, 06:15 PM | #13 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Just buy some 4mm barrel connectors, plug and play.
