05-10-2007, 08:32 AM | #1 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
| $#!& not again!
Ok, something isn't right with my setup.:-( I'm running a Mamba 25 with a Spectrum REC, Hitec 5955TG (steering), Futaba 3305 (dig), UBEC, and powered by a IB4200 battery.......It all started when I smoked 2 servos in 1 day, so I forked out the $$$ for a 5955TG and it was working great noticed it getting prety warm so I shut it down. I threw a battery in it last night and noticed it wasnt turning to well, so I shut it down and disconected the UBEC and put the BEC wire back into the REC and tryed it without the UBEC and I couldn't even turn the tires without it glitchen and shutting down, any ideas on what the problem is and is the BEC not strong enough for just 1 5955TG servo? |
05-10-2007, 08:34 AM | #2 |
I wanna be Dave Join Date: Mar 2006 Location: One Legend.
The Mamba's BEC doesn't flow enough amps for that servo. How many cells are you running? More than 6 makes the BEC even weaker. |
05-10-2007, 08:36 AM | #3 |
05-10-2007, 09:01 AM | #4 |
You have your EPAs set and everything? how hot is the servo?
05-10-2007, 09:05 AM | #5 |
05-10-2007, 09:14 AM | #6 |
What BEC eliminator are you using? Have you measured the voltage it's putting out? |
05-10-2007, 09:18 AM | #7 | |
Here is what I have and where I got it. Ultimate BEC 6V Car / Marine 40 Volts Input / 6 Volts Output conformal coated to resist water $37 + $3 shipping http://www.koolflightsystems.com/ultimatebec.htm | |
