03-18-2005, 08:57 AM | #1 |
Quarry Creeper Join Date: Feb 2005 Location: Atlanta
| Can this ESC handle 2 540RS or 55t Lathe Motors?
I currently own this esc http://www2.towerhobbies.com/cgi-bin...&I=LXAXT9&P=ML and have been using it in my stampede with a 15 turn motor and 7 cells. It handles the power just fine and barely gets warm. Would it be able to handle 2 stock or 55t lathe motors
03-18-2005, 07:51 PM | #2 |
Pebble Pounder Join Date: Jan 2005 Location: Kln, HKG
If I remember correctly .. 540 stock motor has 27 turns .. 2 of them in parallel .. ESC will see the motors as 13-14 turns. Then your IntelliSpeed 12T should be able to handle the load fine but might be a bit warm as this load is close to the minimum of 12T. For 2 of the 55t lathe motors, no problem at all. Look at this for some info .. http://www.teamnovak.com/How_to/Dual.../dual_mot.html . |
03-19-2005, 05:37 AM | #3 |
Pebble Pounder Join Date: Oct 2004 Location: ny
with that esc and stock motors it will work with no heat problems... i use two stockers with an ezxr esc it only has a 17t limit and it worked fine... youll have no problems... Chaos |
