05-14-2007, 07:36 PM | #1 |
Newbie Join Date: Feb 2007 Location: Simi Valley
| Motor torque
Ok, I'm a complete newb to RC Crawling. I'm curious what kind of Torque a good Lathe motor will produce. I know most everyone regears to get to a good crawling ratio, but I was thinking about the idea of leaving the gearing closer stock and going with a low RPM high torque motor I have access to.
05-14-2007, 08:04 PM | #2 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
What truck, what gearing???????????????
05-14-2007, 08:29 PM | #3 |
I haven't decided what to build yet... The concept should be the same regardless. If you can produce more torque, you should need less gear. I just have no idea if a lathe motor makes 50 inch pounds of torque or 5000.
05-14-2007, 08:39 PM | #4 |
Quarry Creeper Join Date: Jul 2006 Location: Formula Off-Roading some hill
I dont think anybody has measured the torque of a lathe motor . but even with a 55-turn ya have to gear it down , its more of a control issue then torque . hope I answered yur question somehow . |
05-14-2007, 08:46 PM | #5 |
Newbie Join Date: Jan 2004
05-14-2007, 09:09 PM | #6 |
There's no substitute for gearing down, the lathe motor will just turn slower. The torque gains are minimum.
05-14-2007, 09:16 PM | #7 | |
RCC Addict Join Date: Aug 2005 Location: VARCOR
| Quote: Best bet is to search and start with the most common/popular set up based on the particulars of your ride. Adjustments in motor turns/gear ratio can be made from that point. | |
