05-20-2007, 12:09 AM | #1 |
Newbie Join Date: Dec 2006 Location: Seiad Valley
| TQ3 glitches and twitches
I've built my brother in law a crawler recently. Since its gonna be a while before he picks it up I've been "Testing" it. The problem is the truck twitches, lurches, and bucks. Is the RX too close to the Speed control?? They're next to each other in a box. Does the antenna routing affect anything? Brand new batterys in the TX and truck. Any ideas?
05-20-2007, 12:15 AM | #2 |
Rock Crawler Join Date: May 2006 Location: Surrey, BC, Canada
Antenna routing has a lot to do with glitching fro sure... Especially if the antenna wire's running along or even against aluminum of carbon fiber... Both are electro conductive and will either aid in propagation of glitches or generate them as well... |
05-20-2007, 12:32 AM | #3 |
Debunking old stereotypes Join Date: Feb 2006 Location: 1st and Amistad
Try lacing your antenna through a piece of cardstock, or plastic, then mount that to the chassis. Does your motor have capacitors?
05-20-2007, 10:19 AM | #4 |
05-20-2007, 10:57 AM | #5 |
RCC Addict Join Date: May 2006 Location: Aroostook county
crystals
05-20-2007, 01:00 PM | #6 |
Winner of the '07 RCC dumbass award! Join Date: Nov 2006 Location: Up on a Mountain, out in the Woods
On a brushed motor, YOU NEED CAPS. The brushes make and break connection as the motor goes around, this creates a interference signal that will cause your truck to glitch. The capacitor's absorb the voltage spikes and smooth out the interference eliminating and radio interference Bottom line, if you have a brushed motor, PUT CAPS ON IT. |
05-20-2007, 11:29 PM | #7 |
Ok then... I'll yank the caps off the 19t I got in a trade and put 'em on the one that don't have any... Thx for the tip...
05-21-2007, 12:13 AM | #8 |
Thanks for the tips guys, sounds like I need to carefully route the antenna and solder some capacitors on the motor.
