03-21-2005, 11:24 AM | #1 |
Rock Stacker Join Date: Feb 2005 Location: Heber, Utah
| Motors
I was just wondering what motors most people were running in there rigs. Lathes, Magnetic Mayhems, or stock cans? How are the stock TXT motors for crawling untill I can upgrade?
03-21-2005, 11:51 AM | #2 |
Say hello to my dactylion Join Date: Jun 2004 Location: On the Boat to Whore Island
We (UTRCRC) are all mostly running lathes... And stock TXT motors should be fine.
03-21-2005, 12:05 PM | #3 |
Rock Stacker Join Date: Nov 2004 Location: Lowell Michigan
the stock silver cans work quite well for general crawling and woods driving the only time you would really want the lathes is for competition crawling or if you get sick of having axle stall which if you run a shafty isnt a problem anyway the only differance is speed and runtime I used the stock motors for nearly a year and when I first got the lathes I thought the battery hadnt charged all the way they are that slow and honestly sometimes I miss that extra wheel speed but not to often Brad |
03-21-2005, 04:53 PM | #4 |
Pebble Pounder Join Date: Feb 2005 Location: Flagstaff
I have the stock silver can motors in my txt, but with x-factor axles and 9 tooth pinions. I feel that they are great,good torque and long run times.
03-21-2005, 07:07 PM | #5 |
Pebble Pounder Join Date: Feb 2005 Location: Watching U Sleep
| lathe motors
If you can afford too try them all. If not the 12v 55t or 60t lathe motors are the most recommended motor for a crawler competition or otherwise. If you like to drive with some wheel speed than the magnetic mayhems seem to be be recommended.
03-25-2005, 01:04 PM | #6 |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
Whats the run time differance from the stock txt can motors to the lathe motors... i run a gd600 and 1 stock can, i get around 40-50 min runtime.... how much run time improvments did you see?
03-25-2005, 02:30 PM | #7 | |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Determining factors are what size battery do you run, are you running dual servos, are servos digital, are you running an RX pack, what's your final drive ratio etc. | |
