06-04-2007, 12:11 PM | #1 |
Newbie Join Date: May 2007 Location: Russellville, AR
| Glitching HELP! i have a Maxx Stick that is glitching pretty bad. I am running the stock EVX with the 7.2v Conversion, the stock 3chan Rx and Tx with two mg 945's for fws. When i turn even with just one end the truck jumps back and fourth. When i unhook both servos and hook up the stock traxxas 2055 it works fine. So i'm thinking that the mg 945 are overdrawing the rx or esc. I have also tried using a 6v Rx pack and eliminating the bec. That doesn't help. I've also tried a Rx pack and still using the bec together still doesn't run right. This might seem kinda stupid to the pros out there but be nice I'm a newb:-( . |
06-04-2007, 12:37 PM | #2 |
RCC Addict Join Date: May 2006 Location: USA
your using 2 servos? if your using a Y harness that may be bad. ive had a couple bad y harnesses and when i bought a EMS brand one that solved the problem. also with 2 servos you will need a 6v receiver battery.
06-06-2007, 09:23 AM | #3 |
So it's all good now. the mg945's can handle 7.2v so i just hooked the pos and neg from the servos directly to the battery don't even need a Rx pack. No more glitching and both front and rear turn lock to lock on thick carpet standing still. |
