03-23-2005, 05:25 PM | #1 |
Quarry Creeper Join Date: May 2004 Location: stuck in a damm jar
| Titanium gear servo by hitec is it worth it
I am just wondering any one using them. Are they even worth it at $125 for 200 ounces of torque.
03-23-2005, 05:42 PM | #2 |
Quarry Creeper Join Date: Oct 2004 Location: vegas
250 oz. i bet it wont break period. its a little pricey but ou wont have to buy a new servo.
03-23-2005, 07:02 PM | #3 |
Quarry Creeper Join Date: May 2004 Location: Boobslando, florida
I went with it only cuz im runing narrowed kongs other then that I really dont see a use for it, if your runing regular tires you could probably do with out it unless you have $$ to blow on a $ 127.00 servo |
03-23-2005, 07:24 PM | #4 |
I wanna be Dave Join Date: Jan 2004 Location: Flagstaff, AZ
They overheat and kill the electronics. That seems to be the trend w/ most digital servos...
03-23-2005, 07:53 PM | #5 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
I'd stay away from digital servos, I bought two 5945mg's and they both died after about 2 weeks. They do get super hot if you don't give them a break to cool frequently.
03-23-2005, 09:31 PM | #6 |
Pebble Pounder Join Date: Feb 2005 Location: Flagstaff
| hitec servo
I'd stay away from the titanium geared hitecs I killed three of them in two weeks that's an expensive lesson!
03-23-2005, 09:55 PM | #7 |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
I've had great luck with my 5995. Also use a Airtronics"358 non digital, 200oz for $100 Alex. |
03-23-2005, 10:07 PM | #8 | |
(Didn't hitec warranty those suckers for you??) | |
03-24-2005, 01:50 PM | #9 |
| damn dont say that I havent killed mine yet but then again I only do about 30min crawl sessions with it.... that would suck nuts to burn that servo up are you guys that are killing your servos runing seperate battery servo packs? |
03-24-2005, 01:57 PM | #10 | |
I've heard Hitec will take care of it for me, I just need to drop them in the mail. I need my 4ws back. | |
03-25-2005, 12:43 AM | #11 |
Pebble Pounder Join Date: Jul 2004 Location: SOJO
i hitec will waranty these???? on the paper it that came with them it said that they wouldnt
03-25-2005, 04:57 AM | #12 | |
I wanna be Dave Join Date: Feb 2004 Location: on a Big Rock
WTF are you trying to say? " i hitec" are you swearing into RCC court? The paper says 2 years limlited, and ............. "Our warranty does not cover cosmetic damages, damages caused by acts of God, misuse, abuse, negligence, improper installation or damages caused by alteration by unauthorized persons. " Thats pretty broad language, but I bet Hitec will take care of it. Radios without EPA's will kill digital servos! | |
03-25-2005, 05:29 AM | #13 |
| hitec servos
I called hitec on monday about the three thay I killed and the service guy seemed amazed that there would be any problem with the titanium geared servos. I still need to send them in anyway thats a good call on the epa does that keep them from overheating? It seems that on my big trucks they get to hot to touch in just a few minutes but on my bulu tlt they work really well.
03-25-2005, 06:43 AM | #14 |
Pebble Pounder Join Date: Jul 2004 Location: Quakertown PA
EPA=End Point Adjustment What that does is exactly what it says, it allows you to adjust the end point of the servo throw. You adjust the EPA for both left and right steering so the servo stops right when your steering knuckles cant move anymore. Doing so puts your servo at "rest", so to say, instead of of still trying to work to push it farther which in effect is like stalling a motor, therefore creating heat. So you guys that are killing these digital servos....how many DO NOT have radios with EPA adjustment? |
03-25-2005, 11:15 AM | #15 | |
I asked the guy at my LHS and he said I'm the only one, he knows of, that has had problems with the Hitec digi's. | |
03-25-2005, 12:40 PM | #16 |
I don't believe the heat is a "digital" thing. I have and have seen plenty of analog servos get hot. More power= more heat. My 5995tg can draw 4 amps at lock. I think thats going to build heat with them little wires. For the guys getting 1 hour of run time on a single battery, the servos can do more work than you main motor, if that make sense. Airtronics has a aluminum case for some of their 200 oz analog servos. So heat is nothing new. If it's too hot, I think it's overwork. May not be the right servo for the job? |
03-25-2005, 12:55 PM | #17 | |
03-25-2005, 01:57 PM | #18 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
My Airtronics 359Zs have an aluminum case, they get warm and don't die. I've also had good luck with Airtronics 357 and 358 servos. The 358s are torquey but the downside to them is that they have have a single plastic gear inside that likes to crap out if the servo takes a hard shot without a servo saver. |
04-02-2005, 05:17 PM | #19 |
Pebble Pounder Join Date: Nov 2004 Location: Lakewood,CA
I figure EPA would save your servo from burning up because it wont let the servo keep trying to move thus generating heat, instead it would just act like you've stopped steering and start cooling down :-P
