06-10-2007, 12:26 AM | #1 |
Pebble Pounder Join Date: Jan 2007 Location: Clovis
| I think i killed my moped...
Well i just installed a new 85turn axiom motor tonight. About 15mins into the first run the car just stopped. At first i thought it was my battery because ive been having connection problems, but it was fine. So i then looked into my moped v16r esc and i just get no power when i turn it on. Everything seems to be connected and no cut wires. I took it apart and i cant see any marks on the board. Has anyone heard of this? Any suggestions? |
06-10-2007, 11:44 AM | #2 |
Pebble Pounder Join Date: Feb 2007 Location: sunman
May have killed the bec maybe? Disconnect the red wire from the esc to the reciever, and hook up an rx pack and see if it works, if not then i dont know?
06-10-2007, 11:51 AM | #3 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
probably a loose wire on the switch, just cut the switch off and solder the wires together.
06-10-2007, 12:26 PM | #4 |
06-11-2007, 12:25 AM | #5 |
I soldered the wires from the on/off switch together. No luck, the thing seems to be totally dead.
06-11-2007, 03:03 AM | #6 |
Rock Stacker Join Date: Nov 2006 Location: us
How many cells are you running? Its only "recomennded" that you run 7, ive been running 8. Ive only had one problem with 3 of them, one got hot, caused a short and went up in smoke. |
06-11-2007, 03:44 AM | #7 |
Im running 6 3500sc cells. I dont know what happpend. Mine never went up in smoke, or smelled funny. It just stopped working.
06-11-2007, 04:35 AM | #8 |
Sounds like somethings loose. Id also try hooking up a reciever pack and see what the outcome is. Youde see what part of the moped is working or not.
