06-13-2007, 07:24 PM | #1 |
Rock Crawler Join Date: Apr 2007 Location: APPLE VALLEY,CALIFORNIA
| Newbee Esc Question
When using the EVX on a clod w/both motors can i still do the single battery conversion ...i notice it says to remove the second motor wires after this mod...or do i still need 2 batteries ??right now i have the stock motors i believe.....also i need to buy batteries can i just use a normal 6 cell stick pack like a 3600 mah...this electric stuff is all new to me so please bear with me here ...thank you for the help
06-13-2007, 07:31 PM | #2 |
Rock Crawler Join Date: May 2006 Location: Surrey, BC, Canada
I run an EVX with the single pack mod done to it and I used to run the stock motors, too, on a Clod... Just make sure to run the motors in parallel... The only issue I had, was the BEC was too weak for an average servo, let alone running 2 servo's... I fixed that by puttin' a 5 cell hump pack on the RX and pulled the red wire from the EVX's RX plug and it all works good... As for packs, I use the SMC 3600 6 cell packs right now... 1 at a time... Any 6 or more cell pack can be used with the single pack mod.. |
06-13-2007, 07:41 PM | #3 |
thanks for the response.....when you say "pulled the red wire from the evx rx plug "do i not use the black and white wire either ?? in other words do i just not plug in the red/blk/wht wires from the evx and just plug the hump pack where the bat plug is on the reciever...
06-13-2007, 10:48 PM | #4 | |
With the red wire removed from the ESC's plug and an RX pack, the 5 cell hump pack, yes, the servo will be quite happy... And the switch on the ESC will still work, too... | |
06-14-2007, 01:42 PM | #5 |
ok ...got it...thank you so much for the help
06-15-2007, 11:14 AM | #6 |
No probz, man... |
06-15-2007, 11:58 AM | #7 |
RCC Addict Join Date: Dec 2005 Location: Beaver Falls
I'm basically doing the same thing as Daviolentone. I have clod motors with evx esc. I run two batteries on my rig (3600/3700) but only using one battery at a time. I get about 3 hours total runtime from both. My application required a receiver battery pack because the evx couldn't handle the servo without glitching. Basically what he told you, he told me too |
