06-24-2007, 08:18 PM | #1 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
| novak super roster
i have a super roster in my super i need how to wire it up to get max power to servos i have a 5955 in front and a 5645 in the rear.i would like to run a rec pack but what wire do unplue from the super roster.diagrm is best. thanks ps i have seach. |
06-24-2007, 08:24 PM | #2 |
No diagram, but this is easy, pull the power wire, red, center, out from the receiver plug and plug your receiver pack into the reciever! Sounds easy anyways! |
06-24-2007, 08:29 PM | #3 |
thats it. are you shear
06-24-2007, 08:39 PM | #4 |
Very sure, I run receiver packs on my super, and have done it that way! |
06-25-2007, 10:33 PM | #5 |
how big of batt pack can i run on the tq-3 rec.like a 6cell 2/3 ok
06-25-2007, 10:37 PM | #6 |
I would not run more than 5 cells, 6 volts personally. If you want even more power to the servos run them directly off a battery.
06-25-2007, 10:56 PM | #7 |
RCC Addict Join Date: Apr 2006 Location: Brighton
The direct to the servo from the RX pack trick works awesome...only drawback is another battery, or 2, to charge and some extra wiring. It really wakes up "sleepy" servos. Be careful if running digitals...they really don't like the extra heat if you bash for long periods of time. I've let the smoke out (literally) of an almost new 5985, and know of a couple others that have done the same. Even the $$$ 5955 isn't immune to the problem...just watch the case temp and get some magic sauce (heatsink paste) for the circuit board and you'll be set. I sold my soul to 666 for the info IT DOES WORK |
06-25-2007, 11:08 PM | #8 |
Rock Crawler Join Date: Feb 2006 Location: Warner Robins
Why not read the instructions: http://www.teamnovak.com/download/in...ter_superr.pdf http://www.teamnovak.com/products/es...ter/index.html |
