08-07-2007, 06:36 PM | #1 |
Rock Crawler Join Date: Jul 2005 Location: Central Coast
| Tower TS80/ CS80 1/4 Scale Servo Gears
Hey guys, I've been using the TS80 1/4 scale servo for awhile now and just recently broke the gear that the servo horn mounts to (the splined part broke off) So I can get new gears cheap enough through Tower @ $4.79 plus shipping, but do you guys know of any metal gears I can use as replacement instead? Search didn't turn up answers |
08-28-2007, 10:59 AM | #2 |
Well first run on a new servo and its now broken in the same place as the other. I even changed the horn around so its not being beat up. I've searched quite abit and haven't found any other gear sets except the nylon gears offered by tower (the two sets they offer are exactly the same but one costs $5 more- hitec model = $9.99 and they are stated as being nylon). I guess these bargain priced monsters aren't really much of a bargain or monster after all. |
08-28-2007, 12:12 PM | #3 | |
I wanna be Dave Join Date: Nov 2005 Location: Crawler practice!
That sucks sounds like you have a bad binding issue, What about running another 1/4 servo with metal gears? going to be alot more money, But the old saying comes to mind ''You get what you pay for'' can we get some more info on your set up? truck base chassis wheels tires esc radio batteries Thanks dude | |
08-30-2007, 03:20 PM | #4 |
Most of the normal TXT mods really, nothing unusual. TXT axles and trans with Revo shafts, wb set to about 15.5", TQ3 radio, normal 6 cell 3000mah NimH's, bottom (ground clearance)/ front and rear sections of chassis cut off, gd-600 with 55t, Super Rooster, savage shocks mounted at 45 degrees (keeps torque twist managable), 40 series Moabs xl's on narrowed cheyanne beadlocks (about an inch taken out), foams are only narrowed width wise, 6 cell battery mounted to upper front links, trimmed stock knuckles (I tried trimming them to see if the servo was just fighting the stops but there was no change there, also made sure the king pins were set loose and that there was no binding in those areas) Servo was mounted infront of the axle, horn facing downward. The first servo was beat on a little bit and regularly bumped into stuff on the approach angle. The second was mounted higher, horn cut shorter and the linkage mount was moved closer to the center of the horn (2nd hole out) and I only had maybe 15 minutes of pretty easy crawling on it and it was broken Last edited by wonder squirrel; 08-30-2007 at 03:26 PM. |
