08-11-2007, 08:55 AM | #1 |
I wanna be Dave Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
| I Think I blew it
I put my 55t lathe motor in the WK last night using the Trinity slide on motor wires. Problem was I put the motor wires on the same side of the motor and didn't catch it until I tried driving the truck this morning and hit the throttle and got nothing. Swapped wires and got the same, plugged in the OE motor and still got the same plus I checked the fuse in the ESC and it's not blown. I've got a Novak XRS that I can swap in it is blown. BTW, yes the motor will turn over under just battery power. Spec wide here's what I've got; Brand New Integy 55t Lathe motor HS625MG servo Dynamite 1000mAh Rx pack Stock Jolt ESC Stock Tx and Rx Red Rock Tires on Axial black/gunmetal Beadlocks with Traxxas aluminum hexs JB Welded into them I have been running 14/96 but was able to swap over to 12/96 gears with new motor. Last edited by BJoe; 08-11-2007 at 09:05 AM. |
08-11-2007, 09:28 AM | #2 |
No magic smoke (thank god, I hate that smell!) and the fuse didn't blow, but I'm at work and the Bandit (which has the XRS in it) is at home so I haven't had the chance to do the swap yet.
08-11-2007, 09:39 AM | #3 |
Quarry Creeper Join Date: Jun 2007 Location: Del mar
Post up when you get home dude, what happens.
08-11-2007, 09:43 AM | #4 |
Will do, just might toss in the Rx from the Bandit too, so I can run on my 3PDF or 3PM-FS radios! Come to think of it, I did have the truck a little wet past couple outings with it. Maybe it's about time to look at stretching the truck a little too......................... |
08-11-2007, 10:02 AM | #5 |
Anybody think the Rooster Crawler will be worth while to pay the money for vs just reusing the XRS until that dies too?
08-12-2007, 06:15 PM | #6 |
| Well I swapped out the XRS and the truck worked fine! Also noticed that if I stick my nose on it I could smell cooked wiring. Swapped the FM reciever over and did a couple other things while I was working on it. Didn't get to bed until 3am this moring because I kept tinkering with it............ |
