Thread: Are cell ratings on ESC's accurate?
Old 09-10-2007, 09:35 PM   #1
Default Are cell ratings on ESC's accurate?
I was just wondering this and also if the motor you run makes a difference for how many volts the esc can handle. like the rooster crawler is rated for 7 nicd or nimh cells. When i'm running my 55t in a light weight 2.2 would i get by safely with running an 8 cell pack? its just 1.2 volts more... would it really be risky? I mean i'd hate to fry a $90 esc by my own stupidity!
RCMFMaxxMan is offline   Reply With Quote
Old 09-10-2007, 09:53 PM   #2
I have ran 8 cell on a tekin rebel2 without problems but I cant guarantee anything
newclod is offline   Reply With Quote
Old 09-10-2007, 10:10 PM   #3
That particular controller has a 27 turn motor and 7-cell limit. So it can safely handle 7 cells with a 27 turn motor. Since you are using a 55 turn motor (= less amp draw). I would say 8 cells would be ok as long as you are indeed using it in a light weight rig. Unfortunately there are to many variables that must be taken into account to be able to give you a definite answer. Plus companies have been known to under rate and over rate there products so your best bet would be to call Novak and ask them since they are the ones that will know for sure.
aggressivellc is offline   Reply With Quote
Old 09-11-2007, 01:16 AM   #4
alright thanks for the advice. i always kind of assumed that companies would under-rate their items to further ensure smooth operation. but yeah that is a good idea to give novak a call. i will definitely do that. thanks again.
Old 09-11-2007, 03:29 AM   #5
the tekin is rated to 10 cells stk or 8 cells mod
by the way does anyone know what stk and mod mean?
some_guy is offline   Reply With Quote
Old 09-11-2007, 05:24 AM   #6
you need to speak of the english
stk stands for stock
mod stands for modified
Like a 15 turn motor on the tr2 i would run 8 cells a 55 you can run 10!! and i have seen it done the tr2 can handle 10 cells!
smokinubyrc is offline   Reply With Quote
Old 09-11-2007, 06:35 AM   #7
i'm only in year 9 and am cr@p at english
