09-12-2007, 07:10 AM | #1 |
Quarry Creeper Join Date: Mar 2006 Location: Australia
| How do i change brushless shaft direction?
How do i change an outrunner brushless motor from a plane-firewall mount to a standard mount for a car?? I've pulled apart the motor, and removed the grub screw, but the shaft wont move from the outer casing. suggestions??? |
09-12-2007, 10:55 AM | #2 |
Quarry Creeper Join Date: Jul 2007 Location: Racking my Brain
A pic would be nice so we can see exactly what you have. Usually you have to tap them to get them to move the first time.
09-12-2007, 02:58 PM | #3 |
You will need to take the bell off the motor and tap the shaft through, it is a press fit. You will need to file or grind a flat spot for the set screw as well.
09-12-2007, 05:09 PM | #4 | ||
Fantastic guys... I didnt want to go belting into a motor before i knew that was the 'approved method' Now, jrh.. grinding a spot for the set screw... i presume your taking about the set screw on the motor endbell that holds the shaft??... because i think i will also need a flat spot for the pinion. btw.. its an Emax BL2215/15... it is SOO clicky when you rotate it.. and it has bearings front and back. i can get some pics if u want. | ||
09-12-2007, 07:20 PM | #5 |
You will need a flat spot for both the pinion and the set screw on the endbell. If the shaft is 3mm just add a wrap or two of aluminum foil to shim it up.
09-12-2007, 07:44 PM | #6 |
.. i just hammered it through to flish with the endbell.. and its still just as tight as it was when i bought it.... do you think i still need to punch it all the way through and file a flat spot on it??
