09-27-2007, 07:16 PM | #1 |
Rock Stacker Join Date: Sep 2007 Location: West Point, VA
| Tazer ESC Problems??
Im runing two 22 turn motors 6t pinions a tq3 and a tazer 12T in my clod buggy. It dies then starts again? Everything turns off then back on again. i dont get it i have tried everything. Is it the crapy motors drawing to many amps? is it the esc? everything is new. and im running a 3300 raido shack battery.
09-27-2007, 07:17 PM | #2 |
Sounds like your BEC is getting overloaded. Are you using 6 cell packs, and what servo(s) are you using?
09-27-2007, 07:38 PM | #3 |
6 cells with twin hitec 645s. This is kinda off topic but will a 75t lathe handle 14 volts? i herd they could handle over 6 cells but how much more? the bec is 6 volts. i have a sperate reciver battery thats 1100 mah 6 volts is there any way i can turn off the BEC? and just run that battery or do i need to just ditch it all for a novak crawler with 55ts?
09-27-2007, 07:40 PM | #4 |
Yeah you are fine with 12 cells on a 75t. To use the RX pack, just keep the ESC switch turned off. Then plug in the RX pack to turn on the rig fully. Remember to unplug your main pack too when you are done. Novak crawler is limited to 7 cells, does that work for you? JRH |
09-27-2007, 07:55 PM | #5 |
thanks the 75ts are going on my soon to be e maxx crawler. thanks for the guidence on the BEC problem. i cant wait to fix this problem its been killing me.
