10-04-2007, 06:07 AM | #21 | |
Rock Crawler Join Date: Sep 2007 Location: 42N 88.02W
10-04-2007, 06:09 AM | #22 | |
10-04-2007, 06:25 AM | #23 |
RCC Addict Join Date: Mar 2007 Location: des moines
hmm how are you guys keep the 5955's from smoking?? i have bad very bad luck with anything hitec that why I use all jr...I just wanted to know how people are getting the hitec to hold up
10-04-2007, 06:52 PM | #24 |
| I don't have problems with the 5955's, the key for me is good steering geometry and properly set EPA's. Plus the heat paste trick helps a bit, up to 20 degree differance I noticed.
10-04-2007, 08:39 PM | #25 | |
RCC Addict Join Date: Apr 2004 Location: 5280
Although even with paste, I did smoke a 5845 on the rear of my super. But then again I run my servos off of a dedicated Rx pack, one pack for each steering servo. Plenty of power and speed with the 5955s! | |
10-04-2007, 10:56 PM | #26 |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
I have only ran 5995 and 5955, I like the 5955 better stays cooler, torque wise they are same. Everybody is right Spend the Dime, or you will regret it. 300oz or better I did some Searching and read about a test on 5955 and the 8711 and the fact that power is lost when they heat up, so I may be buying another servo |
10-05-2007, 06:10 AM | #27 |
I ordered two 5955's yesterday after much deliberation, I seriously considered the 8711's, but I decided to stick with Hitec. I will be using the paste trick too. Thanks again for all of the advice.
10-05-2007, 07:16 AM | #28 |
Anyone using the 359z's ? I know Jia and tc rave about them, But anyone using and how they like them or not ?
10-06-2007, 05:50 AM | #29 |
