10-15-2007, 05:37 PM | #1 |
Pebble Pounder Join Date: Nov 2006 Location: isanti, mn
| tower pro problem
well i just bought a tower pro from jp customs. i had it on my rig for maybe a week or 2 and only ran it a couple times just to test it out. on sat. i had just got in from crawling around my yard when i smelled the wonderful smell of electronics. i immediately turn everything off and disconnected the batt. my hand brushed across the servo and it was very hot. after leting it cool i turned the truck back on and the servo motor engages and disengages. I'm not really sure if this is a common problem or i just got the fluke. if it is a common problem is there anyway i can fix it? thanks for the help |
10-15-2007, 05:44 PM | #2 |
Pebble Pounder Join Date: Feb 2007 Location: Binghamton
what size rig do you have. I have used these servos in all my trucks. I have owned around ten of them. One time I had a problem with one of the servos overheating but it seemed to just be a fluke, also it was pushing 40 series on a really heavy truck.
10-15-2007, 06:06 PM | #3 |
2.2 mashers with a little weight. must have got the fluke |
10-16-2007, 02:40 PM | #4 |
Rock Crawler Join Date: Sep 2007 Location: Colorado Springs
I have been running mine a mg945 for about a month and have put some hours on it. I have had no problems. I am running an AX10 with almost 2lbs on the axles and tires. My bro in law has the same on his with the same run time and no problems.
