11-01-2007, 11:38 PM | #1 |
Quarry Creeper Join Date: May 2007 Location: NCVRCC
| voltage regulator?
At what voltage should a guy run an external BEC or volt regulator? I'm running 9.6V NIMH on a Mamba 25 and BM9 motor.
11-01-2007, 11:53 PM | #2 |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
6 volts is a good place to start. Depending on your servo you may be able to run higher than 6. What servo are you running?
11-01-2007, 11:57 PM | #3 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
I think he means how much voltage/#cells does it become necessary to install a regulator. 8.4, 9.6, 10.8 etc.. |
11-02-2007, 12:09 AM | #4 |
| Ah, I see. In that case I would say the only way I would not run a regulator would be if I were running a speed control that had a 3amp/6volt or greater BEC. And only that with 7.2volt input, powering 1 servo. The only other reason I wouldn't run a regulator is if the servo(s) are run straight off the main pack.
11-02-2007, 12:41 AM | #5 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Castle BEC is the BEC for you. |
11-02-2007, 08:56 AM | #6 |
Pebble Pounder Join Date: Apr 2007 Location: Columbus
So running a mamba max with 3s lipo, 55t lathe and 645mg servo(electronics on the way), I should invest in the castle bec? If I dont will it fry my servo?
11-02-2007, 10:49 AM | #7 |
| No it shouldn't fry the servo, it just won't run at full performance. Like if the tires get in a bind, you won't be able to turn. The mamba max will likely run a little hotter due to the added stress on the BEC. I think the castle BEC is a great investment for any crawler. It packs a large punch for a very low price.
11-02-2007, 06:33 PM | #8 | |
Pebble Pounder Join Date: Dec 2006 Location: Southern Arkansas
I should do that now. | |
11-04-2007, 08:53 AM | #9 |
RCC Addict Join Date: Oct 2005 Location: rite here all along
if you are running a 3s lipo with thw MM and a big time steering servo like the JR8711 403oz you WILL FRY your mamba max..........I know from experience, I did have the long aluminum servo horn on it |
