11-03-2007, 09:25 PM | #1 |
RCC Addict Join Date: Oct 2005 Location: Trussville, AL
| Is this okay with lipos??
For all of you lipo experts, help a dummy out. would it be okay to take TWO 2 cell (7.2v) packs and charge them differently (each with a deans connector on the ends) and then connect them with a y-harness to be ran to the esc's. will the esc's recognize that they are drawing from 4 cells? also since there are TWO 2 cell packs at 1320 mah each, could i consider that basically like a 4 cell 2640 pack now?? thanks guys just want to check so i dont screw up my electronics. |
11-03-2007, 09:34 PM | #2 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
I know depending on how the two packs are wired that it is either 7.4 2640mah or 14.8 1320mah. You running one or two esc's? Last edited by Scattman; 11-03-2007 at 09:53 PM. |
11-03-2007, 09:35 PM | #3 |
RCC Addict Join Date: Feb 2005 Location: Minnesota
first thing is 2 cell lipos are 7.4v It all depends on how you wire them. You could either wire them in series which would double your voltage making it a 4s pack (14.8v) or in parallel which would double the capacity and still maintain 7.4v
11-03-2007, 09:52 PM | #4 | ||
so it sounds like ill be okay it just depends on whether or not i want to connect them in series or parallel | ||
11-03-2007, 09:54 PM | #5 |
| Fixed And all I run is lipo's |
11-03-2007, 10:39 PM | #6 |
Newbie Join Date: Dec 2006 Location: In ur couch steelin ur change
What are the C rating's?
11-03-2007, 10:58 PM | #7 |
11-03-2007, 11:34 PM | #8 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
Hey kevin, you can do that if you want to, wire them in parrallel and you will keep 7.4 voltage and double your mah rating, also you will double the amp draw that you can have. So you will have a 2p2s 2640 mah lipo that will pull 52 amps continuous. I would still charge them sepperate though.
11-04-2007, 06:57 AM | #9 |
If you are running two speed controls I think you are going to need to use one battery for each esc. I don't think you can use a y adapter to connect them all together.
11-04-2007, 07:48 AM | #10 | |
(This should have been post #14 I don't know what's going on here) Last edited by 4u2nv; 11-04-2007 at 08:35 AM. | |
11-04-2007, 08:15 AM | #11 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
| I would recomend that. If your running 2 ESC's and 2 2 cell LiPo's, why bother Y'ing the batteries togther? Just run a pack per ESC.
11-04-2007, 08:16 AM | #12 | |
so you are saying that the 52 amps continuous will allow me to acheive more low end torque but still gain more battery mah I think i read all the previous posts right but might not have | |
11-04-2007, 08:25 AM | #13 | ||
No, you need to y harness the batteries and then y harness the 2 esc's. 2 reasons, 1 for the combined amp draw, you stick your rear in a hole and need to force it out, with only one battery you only have 26 amps to draw from where as you could have 52. And 2, if one pack dies durring a run, which will happen cause one end is gonna need more juice than the other then you are waisting the added capacity left in the other pack. I have been running dual esc's with much success since '05. | ||
11-04-2007, 08:32 AM | #14 | |
Pebble Pounder Join Date: Jun 2007 Location: My House
"Y"ing them together will probably increase runtime though, since the batteries will discharge equally even if one motor requests more power, where if they are each run to a single speed control, the rear motor will almost always have a higher load and thus a higher amp draw than the front, which would cause the rear battey to discharge faster. (edit, how did my post end up above the one I was quoting?) | |
11-04-2007, 08:32 AM | #15 | |
Thats because you fail to see he's either looking for HIGHER amp draw for more motor or HIGHER voltage for increased wheelspeed. Just depends on how he wires it up. | |
11-04-2007, 08:37 AM | #16 |
Ah, gotcha. And thats why I haven't built a super yet. |
11-04-2007, 11:29 AM | #17 | |
No, when you drive a dual esc's clod on seperate channels there are alot of times when you are just driving one motor, one of those being to force your way out of a bind. If the packs are sepperate he will only have 26 amps to pull from on one motor, by running them together he can draw from both packs to power one motor out of a bind. 26 amps in not a lot in a super truck, expecialy in a bind. Same goes for servos, I used to run 2 cool becs on my super truck but I y'ed them together befor the went to the rx instead of one for each servo, because one servo will stall at 5.4 amps, so with only 3 amps avalible with each bec having them sepperate would limit each servo to a max of 3 amps, it I y them together and one is loose and the other hung it will divert power from tboth bec to supply the servo with its max amp cappacity. Kevin, just y them together. | |
11-04-2007, 08:29 PM | #18 | ||
I guess I'l have to stall my 55T Wheely King on a meter tomorrow and see what the amp draw is. If it's less than 15, you buy me a Coke, savvy? | ||
11-05-2007, 09:22 AM | #19 |
Don't run one battery to each ESC, put them in parallel with each other and with both ESCs. This way they discharge at the same time. For a race clod I would recommend a different setup alltogether.
