11-10-2007, 06:50 PM | #1 |
'08 2.2 National Champ Join Date: Nov 2006 Location: UTRCRC
| Steering lock w/ throttle
I have an intellespeed 16t esc running a 27t mod motor and and hitec 5998tg servo direct wired to the esc and when I turn and pull on the throttle the steering stays turned even when I let go of the wheel. When I let go of the throttle it goes back to center. Also even with a charged battery it's really slow too.
11-11-2007, 08:00 AM | #2 | |
RCC Addict Join Date: Apr 2005 Location: Eden Prairie, MN
Sounds to me like the BEC on the Intellispeed isn't strong enought for the 5998TG. I think the Intellispeed is rated at 5volts/1amp. | |
11-11-2007, 08:18 AM | #3 |
11-11-2007, 08:30 AM | #4 | |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
I've overloaded my battery when running 2 5995's straight from the pack and giving throttle. The pack was quite hot at the end of the run and the servos acted like that when it was happening. But I would not discount that the problem could be the servo. Oh, and just so we can be sure the problem isn't wiring related, how do you have it set up? | |
11-11-2007, 10:42 AM | #5 |
I finally got some time to check everything. It was the motor, I don't know if it was too much for the esc or what but I tried the stock motor out of a WK and it was fine. I noticed the motor smelled bad too.
