11-23-2007, 04:24 PM | #1 |
Busy buildin or crawlin!! Join Date: Aug 2007 Location: Castle Rock
| NOVAK CRAWLER ESC works best with what 2S lipo pack?
I'm running the Novak Crawler ESC and was wondering which lipo battery pack is best for it? Book says it can only hold a 2S pack. Which brand and which style is recomended? Pack will be used in a Super and a 2.2 rig, if that matters. Super rig is running 2 ESC's. Thanks for the help... |
11-24-2007, 07:35 PM | #2 |
Pebble Pounder Join Date: Sep 2007 Location: c.s.
I posted on your ither thread about what i use.you'll want too add up the amps that both motors,esc,servos can pull and make sure you don't over amp the lipo.but my 10c rated lipo can have a continuous amp pull of 20 amps.the also sell a 15c rated one that you can do 30 amps continuous.hope that helps.
11-25-2007, 07:07 AM | #3 |
| Thanks for you help. How do I find out how much amps my electrics are pulling? |
11-25-2007, 09:44 AM | #4 |
some other people on here with more experience might know what battery too use.the only thing i could think of is maybe hook up a digital amp meter and put the crawler under load and see what it reads.but im sure alot off people on here use lipos for there supers and will give you some first had exper
11-25-2007, 03:26 PM | #5 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
I would sugest a lipo from holmes hobbies. I use his 4000mah 3 cell, it has plenty of amps to run a super.
11-25-2007, 03:49 PM | #6 |
What ESC are you using in your super, Kamikaze? Did you need two ESC's to prevent from clod-stall? Thanks
