12-12-2007, 08:27 PM | #1 |
Quarry Creeper Join Date: Oct 2006 Location: Great White North!
| Glitching Question...
I had issues before where I lose forward and reverse but still have steering.. I originally thought it was a the motor so I put in a brand new 55t, worked for a bit then same thing.. Then I thought maybe it was my ESC, switched it and same thing.. So I put in a brand new esc.. Same issue.. Thought ok, maybe its the reciever, put in a brand new reciever and controller... Once again same issue.. The only thing I havent changed is the servo... Im wondering if the servo could be the issue? Anyone heard of this or have it happen?
12-12-2007, 09:14 PM | #2 |
Pebble Pounder Join Date: Aug 2007 Location: Da Springs
| More info
What ESC? What radio system? What servo? What battery size? What motor 55t and did it have caps installed? Details man Details! |
12-12-2007, 09:28 PM | #3 |
Sound like a BEC issue to me. Does it crap out on you when you try to steer or is it just random? If you're running a mongo digital servo, it's a good chance it's overloading the BEC. Details will help, like Slickrock said...
12-12-2007, 09:55 PM | #4 |
55t motor.. Tried 3 esc's, a super rooster, a LRP AI, and a Novak something.. servo has never changed.. hitec 645.. Batteries are 7 cell gp 1400mah.. It happens randomly, not always while steering.. I have tried a bunch more stuff tonight since my post and when it happened again I wiggled one of the leads off the brush on the motor, it worked again for 2 seconds and stopped. so dunno if the motor is a dud or what..
12-12-2007, 11:41 PM | #5 |
Newbie Join Date: Apr 2007 Location: Malaysia
Try disconnect all your servos and see whether you can go forward or reverse. I think your servo is robbing all the amps. Super Rooster (not Crawler Edition) and LRP have very weak BEC
12-13-2007, 08:11 AM | #6 |
Even with the servo unplugged it does it.. That angle was covered...
12-13-2007, 09:54 AM | #7 |
One buddy suggested running the motor in a glass of water at low speed to seat the brushes.. Could that possibly be the issue? Is it needed to do this to new motors? Ive never tried it before...
12-13-2007, 01:05 PM | #8 |
That's an old-school motor break-in technique. The water provides a little resistance and cleans out the loose brush material as the brushes wear in. Not exactly necessary with these lathe motors, but it wouldn't hurt. Make sure to hose it down with motor spray afterwards. But if your problem was occuring with both the new and the old motor, it probably won't solve the issue.
12-13-2007, 03:34 PM | #9 |
Rock Crawler Join Date: Dec 2005 Location: West Omaha
Tried caps on the motor?
12-13-2007, 06:41 PM | #10 |
Quarry Creeper Join Date: Jun 2007 Location: Tucson
Might not be the problem, but mine was doing that and I tracked it down to the atenna so I moved my reciver and atenna to a different spot and it solved my glitching issue.
12-13-2007, 07:24 PM | #11 |
Rock Stacker Join Date: Jul 2007 Location: Oakhurst
thats weird i have my tekin rebel two mounted DIRECTLY on top of my 55 turn motor. i have no problems with it, and no glitches.
12-13-2007, 09:41 PM | #12 |
Well Ive tried moving things around.. wiring.. everything.. Im gonna go to my LHS this weekend and pick up a couple new motors I think.. Gotta get this worked out!
12-13-2007, 10:20 PM | #13 |
Have you tried to run the motor direct from the battery?
12-14-2007, 08:16 AM | #14 |
Direct from the battery there are no issues...
12-14-2007, 08:53 AM | #15 |
RCC Addict Join Date: Dec 2006 Location: Flatwoods
Sounds like antenna placement issue. How is your antenna tube ran?
12-14-2007, 07:31 PM | #16 |
straight up...
12-14-2007, 08:56 PM | #17 |
Newbie Join Date: Sep 2007 Location: Hot Springs
What radio system??? What RX??? and does it do it when you are real close the vehicle??? and how old are the batteries?? |
12-14-2007, 09:34 PM | #18 |
Brand new JR Reciever and Transmiter... Brand new Novak esc, new hitec servo.. everything is new...
12-15-2007, 12:12 AM | #19 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
I'm definately no expert on electronics, so I'm just going to put this out there. Could it be a problem with a short in the antenna? I know the covering on them is not very strong at all and it may have ripped or the wire be pulled apart or pulled out of place where it attatches to the circut board in the reciever.
12-15-2007, 09:59 AM | #20 |
Ive tried 2 different transmitters and recievers though... both antennas are fine on them!
