12-21-2007, 08:32 PM | #1 |
Pebble Pounder Join Date: Jun 2007 Location: in rc crawler land
| towerpro servo and traxxas rx
first off i have seached and have failed My question is can the traxxas rx take 7.2 volt, into the reviver because the tower pro can, and if so how to wire it. scott |
12-21-2007, 09:37 PM | #2 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
I'm running a Traxxas RX (#2215) with my TQ-3 TX and have my CC BEC set at 6.6v for my Tower Pro. No problems so far and I have every intention of jumping to 7.2v when I go Lipo. Glad you asked this question though as I hadn't consider the fact that my RX might fry if I do that. Guess I might have to step up in the TX/RX world. As far as wiring it, I believe you will need to get a BEC that you can set for 7.2v. Last edited by Locked Up; 12-22-2007 at 07:32 AM. |
12-22-2007, 07:42 AM | #3 |
RCC Addict Join Date: Nov 2007 Location: Nine Mile Falls, WA
Receivers can handle the voltage just fine 22.0 or 6 volts they don't mind. Servo's in general will handle 6 volts but the more you put to them the shorter the motor life in them. And over 6 volts on a digital servo is really not a good idea. Jason |
12-22-2007, 07:52 AM | #4 |
| So even the receivers that say they are rated for 4.8 to 6v can have higer volts run through them? If that's the case, I'm a happy guy right now. |
12-22-2007, 10:59 AM | #5 |
okay so if i was to take my 6 cell battery and plug it into the bec and take out the red on the esc it would work right |
12-22-2007, 04:45 PM | #6 |
Quarry Creeper Join Date: May 2007 Location: melbourne, australia
yes thats basically what i did i made up a adapter plug thing that i plug in between the battery and esc that plugs into the receiver to power it and the servo's then removed the red wire from the esc |
12-22-2007, 04:54 PM | #7 |
thank you very much do you have a picture |
12-24-2007, 11:14 AM | #8 | |
Jason | |
12-24-2007, 07:12 PM | #9 |
Interesting.... I sent Traxxas an email about my 2215 running at 6.6v and my desire to run it at 7.2. They said it is only rated to have 6v run through it so I'm already pushing it and advised to not run it at 7.2. Course, they are probably just covering their butts. Either way, I'm probably gonna pickup a second unit and try it at 7.2v. I'll let yall know if it blows up or not |
12-24-2007, 08:26 PM | #10 |
Rock Stacker Join Date: Oct 2007 Location: I found Dorothy
I added a Deans connector to my BEC and used a Deans parallel, BEC on one side, battery on the other. Or you can just tie into the battery with the BEC Sorry, meant the ESC side, not the battery Last edited by Les Crawl; 12-24-2007 at 08:28 PM. |
12-24-2007, 10:16 PM | #11 |
12-25-2007, 08:47 AM | #12 |
| It was partly for this Locked Up, just another alternative, I just forgot to quote him in my reply. |
12-25-2007, 01:14 PM | #13 |
12-25-2007, 01:23 PM | #14 |
No "sassin" here, BTW, I like your WK, nice build |
