05-22-2005, 06:45 PM | #1 |
Rock Stacker Join Date: Nov 2004 Location: Lowell Michigan
| endpoint adjustments
Does anybody know if you can mod or adjust the endpoints of the Futuba Magnum Sport Radio? I just seen fritobanditos post about putting endpoint adjusters on a TQ3 and wondered if anybody knew if you could do it to a Futuba Thanks Brad |
05-23-2005, 10:05 AM | #2 |
Pebble Pounder Join Date: Apr 2005 Location: Torrance, CA
Open it up and measure the resistance of your steering pot. Sometimes it'll have it printed on the pot but most radios don't use the full travel so measuring will be more accurate. Once you know the value, get some small pots that are about 1/2 that number and wire them in-line similar to how I wired my switch. The only problem you might have is if alll the components are board mounted and there aren't any wires that you can tap into.
05-23-2005, 03:51 PM | #3 |
Awsome thanks I will have to check that out Brad |
