05-24-2005, 08:09 PM | #1 |
I wanna be Dave Join Date: May 2005 Location: CITY of CHAMPIONS!!
| stripped 2 servos, have a question?
Ok so i had the buggy out last weekend and today. in that time i have stripped 2 hitec hs 645mg servos. was able to fix one of them by ripping it apart and turning the gear that stripped. Now it uses the other good half of the gear! I tried using servo savers originally and they just didn't hack it. The steering sucked! But my question is this. I was looking in a tower hobbies mag and under the servos it lists that the hs 645mg has metal gears and the hs 635hb has karbonite gears. Both are high torque. The 635hb is cheaper, but is it stronger? the paragraph above says the karbonite gears are 4 times stronger than the nylon gears but it has no reference to the metal gear servos. so which one is stronger? And, can you buy rebuild kits for the servos? Thanks |
05-24-2005, 08:16 PM | #2 |
Pebble Pounder Join Date: May 2005 Location: Oregon City, Or
I don't know which is stronger, but I'd go for the cheaper servo as you can replace the gears ~$10 cheaper... because you WILL be busting gears. Metal gear set (645) Karbonite gear set (635) Last edited by Train Of Thought; 05-24-2005 at 08:18 PM. |
05-24-2005, 08:19 PM | #3 |
Quarry Creeper Join Date: Nov 2004 Location: MANVILLE
use a better servo saver,like the kimbrough 124 or ofna hd.you're running this in a buggy and not crawling i'd assume.if you're crawling disredard my statement.even a metal geared servo will have a harsh time in a buggy going at speed.most every one gets away with it in crawlers only cause they're not doing any kind of speed to give the servo a hard hit
05-24-2005, 08:20 PM | #4 |
Rockbound, as I said, I don't know. It would seem that metal would be stronger, but the crazy composites they are coming up with these days make me second guess this kind of stuff.
05-24-2005, 08:24 PM | #5 | |
It is in a crawler, i just call it a buggy because I am used to calling them rock buggies. But it is a crawler! | |
05-24-2005, 08:25 PM | #6 | |
Sorry I noticed that you had said you didn't know after I posted my response. I have deleted it. | |
05-24-2005, 09:16 PM | #7 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
I've been running a pair of Airtronics 359 servos for over a year now and have yet to have one fail. I'm not just running them in one truck, either. I swap them from one truck to the next. No servo savers either. They're not cheap, but I think they're well worth the coin. |
05-24-2005, 10:02 PM | #8 | |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
Jason, is the 359 a digital servo? | |
05-25-2005, 09:53 AM | #9 | |
05-25-2005, 10:15 AM | #10 | ||
http://www2.towerhobbies.com/cgi-bin...&I=LXCHB2&P=ML A note on tower's site about other Airtronics servos using coreless motors: Quote:
05-25-2005, 12:39 PM | #11 |
Quarry Creeper Join Date: Aug 2004 Location: HP lounge
Going a bit off topic now......but would a coreless motor be the same as a brushless? From that little description, it sounds like it. Either way, that servo would be an amazing performer, but I think I'll just save $100 and go with a Blue Bird though. ;)
06-01-2005, 11:50 AM | #12 |
Newbie Join Date: Jun 2005 Location: the netherlands
im using an servo whit karbonite gears (hitec 635or something like that), and i don't really like then, ive stripped 2 sets already so i just replaced then whit metal ones ronnie |
06-01-2005, 04:49 PM | #13 |
RCC Addict Join Date: Mar 2005 Location: Saginaw
06-02-2005, 12:09 PM | #14 |
Rock Crawler Join Date: Aug 2004 Location: woods cross utah
for the price of the airtronics servos you can get the hitec tg series and never worry about it
06-02-2005, 08:05 PM | #15 | |
do you have a link to those? Why won't i have to worry about them? I am not familiar with them! Thanks guys for all your help. I stripped 2 more hi tec servos since i posted this thread. I have bought the airtronic servos, I will give them a try. I would like to check out the hitec tg servos though! | |
