07-19-2019, 07:35 AM | #1 |
Pebble Pounder Join Date: Mar 2011 Location: Florida Gulf coast
| Can I use Axial SCX10 12mm hexes on the Enduro?
I have a bunch of aluminum 12mm hexes for the SCX10 in my parts bin and was wondering if they would be good to use in place of the plastic ones on the Enduro. I’m away from home on business and don’t have the ability to try it now. On that note, if it does work, what other parts can be used? Just a thought. Thanks. Last edited by RABIDFOX; 07-19-2019 at 07:37 AM. Reason: Spelling errors |
07-19-2019, 08:02 AM | #2 | |
Quarry Creeper Join Date: May 2017 Location: Bellevue
| Re: Can I use Axial SCX10 12mm hexes on the Enduro? Quote:
I tried putting a set of metal 10.2 hexes and they don’t work. They taper down towards the end and don’t quite make it to the pin. Sent from my iPhone using Tapatalk | |
07-19-2019, 08:18 AM | #3 |
I put generic 7x12 and they work great Hang up and Drive |
07-19-2019, 10:39 AM | #4 |
Quarry Creeper Join Date: May 2019 Location: North Highlands
| Re: Can I use Axial SCX10 12mm hexes on the Enduro? |
07-19-2019, 11:20 AM | #5 |
Its actually a 5mm hole thats needed, I just double checked with calipers. 6mm is the thickness of the hex What I usually end up doing is drilling them out myself. I've designed a jig that can be 3D printed, if you want me to share it I could post it up on Thingiverse, let me know. Last edited by HumboldtEF; 07-19-2019 at 11:24 AM. |
07-19-2019, 11:29 AM | #6 | |
Handy little jig, if I'm ever in need, I'll hit ya up, thanks! . Last edited by punkindrublik; 07-19-2019 at 11:31 AM. | |
07-20-2019, 07:26 AM | #7 |
Rock Stacker Join Date: Jul 2019 Location: USA
My RTR had a wheel that was a little warped. So I decided to try a set of Axial 8 hole I had laying around. When I tightened the axle nut, the wheel wouldn't turn. Went to the hobby shop and bought some wider Traxxas hexs and that solved the problem. They're plastic however.
10-30-2019, 04:27 AM | #8 | |
Quarry Creeper Join Date: Oct 2017 Location: The Netherlands
10-30-2019, 08:06 PM | #9 |
10-31-2019, 08:51 AM | #10 |
Thanks!
Can I use Axial SCX10 12mm hexes on the Enduro? - Similar Threads | ||||
12mm Hexes??? | JBHardwear | Tires and Wheels | 3 | 04-11-2008 07:01 AM |
12mm Hexes | rdt45 | Tires and Wheels | 7 | 04-23-2007 08:25 AM |
