| | #1 |
| I wanna be Dave Join Date: May 2005 Location: CITY of CHAMPIONS!!
| ok, so after just playing around for 10 min i tore my new panther tires with the lock out on the rear of my berg. :-( i knew this was going to be a problem and i wanted to do something wuth it but just didn't have the chance and my new panther cougars came and i had to try them, never though i would tear the tire first time out o -well live and learn. on to the fix i used all the stock stuff just modified it a bit. the first pic shows were i drille the new mounting hole, it is 1/4" in from the original hole. i didn't cut off the end because there was room for it and just in case for what ever reason i wanted to change it back. second pic shows the cut off from the knuckle. after i remounted the link i swung it as far over as possible till it hit the housing for the knuckle, then centerd the knuckle and re drilled a new mount hole. third pic shows the new mount on the knuckle, i groubd in back round and smooth and you can see it is tucked far in by the rim!! no more ripped tires for me!! ![]() ![]() |
| Sponsored Links | |
| | #2 |
| . ![]() Join Date: Nov 2005 Location: Rock chucking territory
| | #3 |
| hmm. i hope not! if so that set up looks nice i will try that! be nice if some one would come out with a straight axle adapter for these things!! hey rc4wd hint hint!! |
| | #4 |
| | #5 |
| Team Nylint ![]() Join Date: Jul 2006 Location: Elberfeld
| | #6 |
| sweet! i haven't seen that!! |
| | #7 |
| I wanna be Dave Join Date: Apr 2005 Location: It's good to be a Pirate!
| | #8 | |
| Dream...Think...Create. ![]() Join Date: Jun 2007 Location: Crawler Innovations, Tyler, TEXAS
| | #9 |
| Rock Stacker Join Date: Jul 2006 Location: Tacoma
| So I might be missing something but what's to stop the front's getting caught on the steering nuckles? Might we need to find a Mod for that as well? |
| | #10 |
| the will, i made my front 1/4" wider over all, this pulled the tire away a little more, for the moment its the best i can do, just have to be careful. |
| | #11 |
| | #12 |
| Rock Stacker Join Date: Apr 2008 Location: Norcal
| Is this mod necessary if you're using the stock rims with panthers? I havn't assembled mine yet. Thanks. |
| | #13 |
| Even with stock rims, the Courgars will wrap around the rear arm using stock foams. |
| | #14 | |
| | #15 | |
| | #16 |
| Hmm..I'm a bit worried now. I have some Meyhem wheels in the new ocm offset on the way. with Panthers on the way as well. I was going to do the rear lockout mod. I guess i'll be looking for other ways to mod the front as well. Startin to wish I went with Rock Claws. |
| | #17 |
| It'll still rip the claws!! Seen it happen at the ECC comp. |
| | #18 |
| Thread Tools | |
| Display Modes | |
