Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > EnRoute Berg
Thread: Berg Newage Shock Fix
Old 06-08-2008, 08:56 PM   #1
Mic
Default Berg Newage Shock Fix
The stock shocks on my Berg leaked just standing still. I took them apart and discovered that there were no O-rings in the seals just a plastic wiper. I had an Associated #6440 shock rebuild kit for an RC10 in my tool box. I added 2 orings and a teflon spacer, Fixed, no more leaks. You may be able to just add some of the o-rings from the kit but I had the #6440 in my box and it had the right size teflon spacer.
Mic is offline   Reply With Quote
Old 06-16-2008, 03:15 PM   #2
Is this correct? I used the stock rings? I just want to double check as I have never built shocks before. Thanks
RCbasher is offline   Reply With Quote
Old 06-16-2008, 05:37 PM   #3
Mic
That is correct I added a teflon spacer to put some tension on the rings to make sure they sealed. You can run it like you have it and if it does not leak I would leave it like that but if you still get a little leakage try adding a shim to add a little presure.
Old 06-16-2008, 05:42 PM   #4
Thanks for the quick reply.
