Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > EnRoute Berg
Thread: Team RCC Berg: Nluv's
Old 06-13-2008, 02:41 AM   #1
Axial Team Driver
Brandon's Avatar
Default Team RCC Berg: Nluv's
Finally getting around to building a Berg axle'd rig. I think I have all my ideas in line so time to start building!
FYI if you order the axle kit you wont recieve any of the servo mounts. No big deal for me I will fab something up and I am sure others will be doing the same
Parts list so far:
Berg axles
2 55t lathes
mamba max
hitec 5998
castle bec
losi shocks
Mayhem Berg offset wheels
Chassis is still in the early stages of planning. I have a set of blackjack plates that will work great for now. Thanks Franky Rizzo!
My mess from tonight
And the actual hardware included with the axle kit
Brandon is offline   Reply With Quote
Old 06-13-2008, 02:59 AM   #2
damn that after school paper route pays well
gonna be nice seeing all the different berg ideas floating around
cheers
BoNuS LiNe is offline   Reply With Quote
Old 06-13-2008, 12:46 PM   #3
Mayhem Eng.'s Avatar
I will get started on them next week. Let me know what you need when you get a chance.
Mayhem Eng.
Mayhem Eng. is offline   Reply With Quote
Old 06-13-2008, 01:20 PM   #4
Axial Team Driver
Brandon's Avatar
cheers
Its not going to be easy to keep up with all your ideas!
Mayhem Eng.
PM Sent, thanks Mayhem
Old 06-13-2008, 01:32 PM   #5
1 man, 2 sons
Unimoger's Avatar
sweet pile brandon, is it done yet?
Unimoger is offline   Reply With Quote
Old 06-13-2008, 05:57 PM   #6
Axial Team Driver
Brandon's Avatar
Nope, the pile still needs a few more parts
Old 06-16-2008, 09:20 AM   #7
Alright Brandon stop spending money you have a wedding to pay for....wait go ahead you won't have a chance after you say "I Do"
drumbeater is offline   Reply With Quote
Old 06-16-2008, 12:12 PM   #8
I used the same lower links with my Berg/BJ setup.
Have fun with that servo mount.
FrankyRizzo is offline   Reply With Quote
Old 06-16-2008, 01:36 PM   #9
Axial Team Driver
Brandon's Avatar
Exactly!
Still trying to figure that out. I think I got it though
Old 06-17-2008, 10:34 AM   #10
Axial Team Driver
Brandon's Avatar
Finally got to sit down and work on this last night. Almost a roller, still need to figure out steering but I have an idea
Started by trying a chassis design I have always wanted to do on a 2.2 but it wasn't working out so well so I followed Jason's idea and used the stock AX-10 chassis. I knew there was a good use for it! Didn't need any pics of Jason's setup, this was too easy! Made my own skid and got the losi shocks mounted.
This will be my first comp rig using shocks this long and this much ground clearance. Its going to take some getting used to.
Old 06-17-2008, 10:52 AM   #11
bergs well you dirty dog you. and going to try some panthers too cheater. j/k cant wait to see this thing in action. very nice brandon im envy of you 8-)
maro69camaro is offline   Reply With Quote
Old 06-17-2008, 05:00 PM   #12
I've got tire perfect tires for you free 2.2 Rock stompers
Old 06-17-2008, 06:49 PM   #13
Axial Team Driver
Brandon's Avatar
Thanks Cody, I will let ya know when I get it done and test it out locally.
Thanks Steve, you are always looking out for me
Old 06-17-2008, 06:51 PM   #14
are you going to clock your axles ?
it's super easy
Old 06-17-2008, 06:56 PM   #15
Axial Team Driver
Brandon's Avatar
it's super easy
I think I am going to leave the front. Having all that weight that much lower is a huge stability advantage. Not only that, unclocked it still has more clearance than my tlt axles.
If it becomes a problem I will probably clock the front 15*
Old 06-17-2008, 11:11 PM   #16
What can I say I'm just a helpful guy
Old 06-18-2008, 04:08 AM   #17
TCS/Holmes Hobbies
SVEN's Avatar
For a servo mount, I made a U bolt out of 6-32 all thread and ran it through the bottom of a piece of aluminum angle with the servo shape cut out of the vertical face. Then used the hole in the top of the axle link mount to keep it from moving side to side. I haven't had any issues with it yet.
Pictures explain it better...
SVEN is offline   Reply With Quote
Old 06-18-2008, 01:53 PM   #18
Axial Team Driver
Brandon's Avatar
Thanks SVEN. Thats very similar to what I had in mind.
Did you figure out why your axles are so loud? Mine SCREAM at low rpm
Old 06-18-2008, 04:36 PM   #19
pinion gear mesh will cause a lot of noise , when i had the motor mounted behind the axle during a steep climb i slid back down rather hard hitting the motor and it shoved the pinion into the gear causing all sorts of loudness .
i found that playing with gear mesh really changes the harmonics and tone the crawler makes
Old 06-18-2008, 04:57 PM   #20
Axial Team Driver
Brandon's Avatar
What gear pinions are you running? I agree about the mesh though, I think with metal gears the spacing can be larger (which should make them quieter).
