| | #1 |
| Rock Crawler ![]() Join Date: Jan 2006 Location: PNW!!!
| Wanted to share my build with ya all. You will find some of the well thought out ideas from previous builds incorporated into mine. Some with a few changes to work with my rig. I figure if it works, why try to reinvent the wheel right? Kamikaze Kustoms ZERO Chassis JR 8711 Servo HH Pro Hand Wound 45t motors Losi Shocks Tekin FX ESC Hitec HS-65MG Micro Servo 2 RadioShack Submini switches (275-017A) 1320 3S Lipo Nomadio Receiver Mayhem Berg Spider Wheels with Custom Rings Panthers Nwtractech Foams Started off with clocking the front axles. ![]() ![]() Front & rear dig from submini switches and a Hitec HS-65 micro servo. ![]() ![]() ![]() ![]() Electronics. I fabbed up some skidplates using 2 3\16 X 2 1\16 Delrin. Once I put the chassis and skid plates together I was like, "So where the hell am I gonna put the electronics??" he he I know there was alot of questions on the front/rear dig wiring set up. I sure did. I hope these close up shots will help answer some of the questions people have been asking. ![]() ![]() Due to the limited space I thought it would be appropriate to use the new Tekin FX for this build. It fits so nice in the chassis. ![]() ![]() ![]() Making it slippery. he he Although there is more clearance with these axles then your typical tlt, Axial, etc., aluminum sucks when it contacts rock. So I went Teflon crazy on the bottom side of the axles. ![]() ![]() 99% completed ![]() ![]() A few more items still need to be added. I'll update when they are installed. Last edited by SMR4RUNNER; 07-02-2008 at 09:46 AM. |
| Sponsored Links | |
| | #2 |
| Newbie Join Date: Jun 2008 Location: UK
| Wow, that is nice, I have ordered the Berg and the Zero chassis .. lots of great ideas on this build !! I do like how you mount the battery and the dig .. and good call on the teflon for the bottom, let us know if it holds ---- Ok, I am a nitro guy, so pardon the stupid question but .. how do you power the nomadio receiver ? Last edited by NullMind; 06-23-2008 at 04:56 AM. |
| | #3 |
| Pebble Pounder Join Date: Apr 2008 Location: Indiana
| | #4 |
| Quarry Creeper Join Date: Feb 2008 Location: no more lockers
| super clean build cheers |
| | #5 |
| I crawled that crack ![]() Join Date: Aug 2006 Location: under a rock and a hard place
| | #6 |
| DOOH!!! ![]() Join Date: Feb 2007 Location: *
| Looks great!, Very clean build May i ask why the dig switches instead of running dual speed controllers with the 4ch? Easier? No real benefit from being able to set the rear for a percent of power compared to the front? |
| | #7 | |
I considered the dual speed controllers but didn't see any real advantages. Dig switches does the same thing. Cost for building the dig. $32 You can also adjust rear speed with different pinion gears. Cost $8 Space was a huge factor as I wanted to minimize as much as I could. So total cost could run you about $40+ as opposed to another $100 or so for another speed controller and you would have to find another spot to put the darn thing. | |
| | #8 |
| | #9 | |
Thanks for the info | |
| | #10 |
| Rock Stacker Join Date: Jul 2006 Location: Tacoma
| Heya Mike. I've been working on my WARCRC comeback build. I just finished clocking my axles. I did a cruddy job cus I suck at Fab but, good enough.. I have an order of Mayhem wheels coming in today or so as well. I was hoping to come back and see no one in WARCRC running berg axles yet Looking good! |
| | #11 |
| Hey Tom. Glad to hear your making a come back. If you make the next comp, you may very well be the first to comp locally. I wish I could run a local comp before Donner but it doesn't look that way. That Nathan is soo sneaky!! Chime up Nate!!! |
| | #12 |
| Axial Team Driver ![]() Join Date: Feb 2005 Location: OC
| Looks great man! I really hope I can make it to Donner to meet you |
| | #13 |
| You gotta make it. I would great to meet another RCC Team member!! |
| | #14 | |
The Teflon sheet is by Team Associated. They called their Chassis Protective Sheet. I'm told they come in different thinkness. The part #9787 is perfect for molding around tight corners. | |
| | #15 |
| Moderator ![]() Join Date: Apr 2004 Location: In my head
| Nice build!!! What links are you running? The lowers look like stock links with revo ends, did you redrill and tap the lowers for 4mm? |
| | #16 |
| | #17 |
| | #18 |
| | #19 |
| Rock Crawler ![]() Join Date: Oct 2007 Location: Auburn
| I Met up with Mike and Hotwheels during lunch today and this thing drives very well |
| | #20 |
| have you found any problems in running the losi shocks with it (100mm) .. as kamikaze advises 90mm shocks for this chassis ? |
| Thread Tools | |
| Display Modes | |
